4l80e reverse and transbrake issue
once the car reaches normal operating temp it stops going into reverse and the transbrake no longer works. However, all forward gears work with no issues, manually and automatically. Its a conundrum we cant seam to figure out. Fluid is on the money checked in neutral while hot and running. Transmission was originally fully built with zero miles. CK Valve body D321 auto shift came out of a fully built transmission with zero mile that went wrong from the get go and ended up reaching undesirable temperatures during test drives. The temperature issues were caused by poorly built transmission internals mixed matched late and early 4l80e case parts and supporting mods were overlooked. We had the transmission rebuilt and used the same Valve body pretty much corrected all the internal issues and supporting mods. Reverse and TB issue continues. All else works like a charm with no issues after rebuild and temperature stays between 175 and 180 degrees. My last resort is to remove the Valve body and send it back to CK for an evaluation and repair. Then re install and hope reverse and TB work as it's supposed to. Any advice on what this issue can be? Most people I spoke to point to the VB. Thanks any help is greatly appreciated.
a pressure test should have been included in your diagnosis and description of the issue.
perform a pressure test and if it is good, you'll need to adjust the rear band clearance
Trans temp 118 degrees 1k rpm (still cold)
P 160 psi
R 120 psi
N 160 psi
D 130 psi
3 130 psi
2 130 psi
2 140 psi
1 100 psi
After 135 degrees we lose reverese and transbrake doesnt work. Reverse tends to go in and out. And at the following temperature the reverse and transbrake completely gone.
Test at operating temperature
Trans temp 160 degrees (operating temp)
P 125 psi
R 60 psi
N 145 psi
D 110 psi
3 90 psi
2 100 psi
1 80 psi
Trans temp 183 degrees (hot )
P 115 psi
R 55 psi
N 120 psi
D 120 psi
3 65 psi
2 90 psi
1 100 psi
This valve body does not have an EPC it is modded to maintain max line pressure. But the line pressure seems to drop psi as temperature increases. The car doesn't seem to have an issue in forward gears. Only issue in reverse. Any ideas? Definitely looksike line pressure issue. But what is causing it?
Vacuum check would be the best place to start.
You can drill a hole or trim a slot in the separator plate gaskets to force max line in other means...but I wouldn't recommend that other than a last resort
need to inspect still...if you have fixed line and that is your pressure, you have an issue
I'd also recommend you disassemble the EPC and modify it
There are instances where the pintle inside the epc gets hung open to exhaust and has issue.
modifying it or buying an EPC plug from Jake's Performance would be the proper way to ensure no issue there
and pressures are still that low...then you likely have an AFL valve issue or possibly a worn boost valve
Just for peace of mind...I don't see you listing any RPM values for those numbers after the first couple where you say 1000 rpm
Do the tests at 2000 so there is adequate pump volume and if they are still low...THEN start looking for the cause of the pressure loss
If they come up with throttle, we will need to search elsewhere
The only thing that am wondering about is the following... The current setup with the CK trans brake VB instructions say to use the ***** in position 1, 3, and 10 and delete the rest. However, since I am no longer using the trans brake for this test. instead, I am using modified VB without the trans brake so it should all work as a high-performance transmission operating as normal without the trans brake or epc, should we use all the ***** in the original OEM application, or would it not change the results if I use all the OEM positions for the ***** without deleting the rest as instructed by CK's D321 trans brake inductions?
thanks for sharing this rare problem, i don't have reverse either, gonna work with the servo cup and rod tomorrow, i put the pin extension from the fix kit on the rod, still had no reverse so the pan and valve body is back off, i measured .120" throw distance but this is the higher end of the spec range, gonna try to get it down to .080" if i can. stick a snake cam and a pick up there and see if i can move the band when the cup is applying the rod.
