Disptick Calibration
This might sound silly, but the question is about the oem full mark vs the new pan gasket level full mark.
The new mark at the pan gasket should be full on vehicle running or shut down?
Its full right now on gasket level when car is running in P and everything is fine.
when i shutdown the vehicle, the level rises so high... so i want to double check everything is fine 😅
Yes, the level will rise when the engine is off as the fluid in the torque converter drains back into the trans. Hence when someone wants to check the trans level with the engine off, e.g. when filling an empty trans, I say it should be about 1" above the Full line.
My personal f body was over a qt off
Have seen multiple customer 3/4 trucks with 4l80e's that are off by multiple quarts.
If you care about a fresh build...check it
