TH400 Rebuild kit
Old Oct 27, 2022 | 05:33 PM
oldfogey47's Avatar
Default TH400 Rebuild kit
Couldn't find a thread with this info, so
I'm going to try my first automatic transmission rebuild and I want a kit, for a TH400, that has "everything" that I will actually need.
It's a street/strip type rebuild, no huge horsepower here, just a strong reliable build.
Thanks...
Old Oct 27, 2022 | 09:56 PM
vorteciroc's Avatar
There is no such Product that includes everything that "you" will need.
There are too many variables as to which Components/ Parts will need to be replaced or upgraded.
Old Oct 28, 2022 | 08:55 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Thanks...
What are your goals with the transmission? We offer nearly every part imaginable for a TH400 with a lot of different kits. It may take a kit and a few extra parts but I'm sure we can provide everything you will need.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Oct 30, 2022 | 05:33 PM
Tranzman's Avatar
Best thing is to tear it down first. Check everything over very closely. Decide what you want/need to replace, what can be reused. Order the parts you want/need.
I like to replace all frictions, bushings, sprag's/one way clutch's, torrington bearings, modulator Etc. I'll reuse steel plates as long as there are no metal to metal contact or hot spots.
Vorteciroc is correct, there really is no real "kit" that has everything!! Why?, because every unit is unique for a parts list. Sure there are common part's that are replaced in every job, but not every part required to do the build comes in the kit.
Because of covid, suppliers are out of things a lot and I've spent more $$ on Ebay than ever.
This is a decent "Banner kit" that would get you started on your journey.
https://www.ebay.com/itm/18552429068...Bk9SR8i7k62FYQ
It would give you things to do while your waiting on the other parts needed after you tear it down.
I buy everything from wittrans.com after I have made up my parts list.
Old Oct 31, 2022 | 06:03 PM
vorteciroc's Avatar
Good to see you around Dalton!
Old Nov 4, 2022 | 12:04 PM
LS1Tech Sponsor
Thanks Vortec! unfortunately I'm writing this from home thanks to COVID. Hope all is well up in your neck of the woods.
__________________
1-866-726-8358
FTIPerformance.com
