4L60E Removal
Old Nov 25, 2022 | 11:14 AM
blackbirdls1's Avatar
Default 4L60E Removal
So i've seen threads and have done some research. May tackle this soon as part of taking out the motor project. I do have a rear main seal leak I believe. How high do I need to have the car to remove this from the floor. I'm a smaller dude and can work around. Will race ramp heights be enough?
Old Nov 25, 2022 | 05:29 PM
Spankstangs1999's Avatar
I took out my t56 on 10" wheel cribs. I did have to jack up car a bit more to roll out on jack. Your gonna need a bunch of extension's.
Old Nov 25, 2022 | 06:37 PM
strutaeng's Avatar
I'm currently working on a rear main seal on a 2500 SUV LQ4, so not much help on the lifting part. 😕
Are you replacing the barbell resistor? I ordered a new one after reading I should go ahead and replace it. I also ordered an SinCity rear main seal centering tool. But the videos I've seen don't really mention anything about it. 🤷
Old Nov 26, 2022 | 06:40 PM
wssix99's Avatar
Save the manuals!
Why are you pulling the engine to replace the rear main seal? I pulled my transmission and had easy access to the rear cover to do the job.
Old Nov 27, 2022 | 07:59 PM
Was going to possible rebuild, it depends what i find or see where the leak is. I think its the rear main though.
Old Nov 27, 2022 | 11:19 PM
wssix99's Avatar
Save the manuals!
Here's the sticky on the bottom engine removal. There are pictures, which may help you judge how high you need to lift the body. (Looks pretty high.) https://ls1tech.com/forums/general-m...ls1-fbody.html
Old Nov 28, 2022 | 05:31 PM
bbond105's Avatar
If removing the engine from the bottom, you are going the have to get the car a lot higher than ramps. You also won't be able to support the car with the front wheels because the front suspension has to come out.
