Stock 4l80 Flexplate with Powerglide
Old Dec 6, 2022 | 06:56 PM
TtypeLS's Avatar
Default Stock 4l80 Flexplate with Powerglide
I’m a newb, hence this section. I’m wanting to know if I can use my stock Flexplate with my powerglide. Original combo was a 2009 LY6/4l80 from a GMC 3500. It’s going into a 1985 Buick T-Type. Street legal but 90% drag car.
Old Dec 7, 2022 | 05:53 PM
jetech's Avatar
Veteran: Air Force
I would suggest purchasing a SFI approved flexplate if you are building a high-performance vehicle.
Old Dec 7, 2022 | 07:35 PM
TtypeLS's Avatar
Thanks! Do you know if the stock Flexplate will work?
Old Dec 8, 2022 | 07:07 AM
MaroonMonsterLS1's Avatar
Did you read the stickies?
The answer to your question is...sortof
You can make any stock flexplate work if you order the converter properly to match
With a stock 4l80e flexplate you'll need a standard "th400" converter
meaning standard short pilot
and standard 11.5" bolt circle
