4l80e center support sits too high
Old Dec 18, 2022 | 05:22 PM
IK746's Avatar
Default 4l80e center support sits too high
Mid rebuild on a 4l80e and I cannot get the rear assembly to stack up correctly. No matter what it's sitting above the bottom of the beveled snap ring groove
I've checked obvious stuff like looking for a second thrust under the center support but still no dice.
All the hard parts are as they came out of the unit so I'm left scratching my head.
Anyone have any thoughts?
Old Dec 18, 2022 | 06:46 PM
badass68's Avatar
Output shaft bushing needs to be recessed. Can’t be flush or will cause your issue.
Old Dec 18, 2022 | 09:42 PM
IK746's Avatar
Thank you! I'll give that a shot
Old Dec 18, 2022 | 10:31 PM
strutaeng's Avatar
Some transmissions have a shim under the center support that looks like a lug case snap ring. Does yours have that?
Old Dec 19, 2022 | 06:22 PM
IK746's Avatar
Yeah I've got the thin spacer ring under the center support
Old Dec 19, 2022 | 06:24 PM
IK746's Avatar
Alright, with recessing the case bushing I was able to barely eek into the acceptable range for rear end play.
I came in at .006 on the dial indicator with zero shims under the rear roller bearing.
Anything to be concerned about?
Old Dec 19, 2022 | 06:28 PM
strutaeng's Avatar
I believe the Sonnax article that I read stated this should be .007" to 0.019", so just barely outside. Can you try to recess the bushing more? I was going to ask if you replaced the rear thrust washer, but seems like you rollerized the output shaft. Probably swap for a thinner washer.
Old Dec 19, 2022 | 07:51 PM
IK746's Avatar
Good to know, my book says .005 to .025. I'll seat it deeper and see what that does.
Thanks!
Old Dec 19, 2022 | 11:11 PM
Tranzman's Avatar
Thanks!
I try to keep the rear clearance to .010. The fwd hub usually needs a thicker thrust washer too.
https://www.sonnax.com/parts/1996-fo...ub-washer-rear
I keep these in stock, it's made in two sizes .078 & .094
Old Dec 31, 2022 | 11:33 AM
5.7stroker's Avatar
As of late, I've been seeing this issue come up often from folks on facebook where the center support doesn't sit in the correct location. Making this post so that I can reference it next time someone has the issue.
Causes are typically:
1. Small thin ring not installed or wrong snap ring placed in wrong locations
2. Incorrect year center support for the case
3. Case bushing protrudes too far into the case
4. Output shaft bearing not assembled in correct orientation.
5. Output shaft bushing not seated correctly far enough into shaft.
Old Dec 31, 2022 | 02:31 PM
truckdoug's Avatar
I recently tore down a '99+ unit that had a 97/98 sun tube in it, made a pretty good mess of the thrusts in the rear section.
Old Dec 31, 2022 | 04:18 PM
5.7stroker's Avatar
I can only imaging the mix and match part builds you've come across lol. Did they at least try to put fluted bushings in it being that it was placed into a late unit? I started to document the differences in parts between the years here, but it's still a work in progress.
https://ls1tech.com/forums/automatic...fferences.html
Old Dec 31, 2022 | 11:22 PM
truckdoug's Avatar
97/98 had fluted bushes, but they had the "short/early" sun tubes.
If you put a 99+ sun tube into any early unit the result is a big glittery mess.
