4l80e center support won’t seat correctly
I rollerized the rear along with the no walk bushing.
I also have the thin snap ring that the center support sits on.
Any thoughts on this or advice would help me out a ton. Thanks
I was able to get a clearance of 0.014.
The last question I have is wether or not I can interchange the 2003 intermediate sun gear shaft with the one from 97? Thanks
The long splines on the 3rd design sun gear shaft (99+) are approximately .040” longer than 2nd design. (97-98)
You can't swap just the sun gear shafts between the two years (97 and 2003)
Suggest reading this document very carefully which goes into details on some of the differences and what can be swapped with what: https://www.transgo.org/demo/06-45-4...be-Changes.pdf
