1st gear+ OD = 5 speed ?
Old Feb 24, 2023 | 12:04 PM
Full Power's Avatar
Default 1st gear+ OD = 5 speed ?
4 solenoids in a 4L60.
What happens if we engage 1st gear clutch AND Overdrive at same time ?
1st gear + OD gets close to a 2 to one reduction ratio, fill in gap between 1st and 2nd.
5 available forward ratios.... 4L60 becomes a 5L60
Anyone done this ?
What is the down side ?
Old Feb 24, 2023 | 01:13 PM
MaroonMonsterLS1's Avatar
Um
What?
I've covered this before.
The 4l60e is a 2 speed transmission with an overdrive reduction
What we call
1
2
3
4
is really
Lo
Low OD
High
High OD
Can break down the ratios if you need to see the math...but that's all that is happening
Not sure where you get the idea that there are 4 shift solenoids either
Shift sol A
Shift sol B
TCC enable
TCC Reg
3-2 downshift control
EPC
only 2 of those 4 have anything to do with what ratio is active.
Old Feb 24, 2023 | 06:11 PM
Full Power's Avatar
okay, I got it.
TWO solenoids.
TWO Planetary sets.
4 speeds forward.
.... 4L60...
Thank you for the explanation.
