4l60e issue
Old Mar 10, 2023 | 08:35 PM
Hhb02's Avatar
Default 4l60e issue
I'm looking for help on my transmission issue. I have a 4.8l and 4l60e from a 2000 chev 1500 2wd swapped into a 1986 s10 blazer 2wd. The transmission will go into drive but it won't shift thru the gears automatically. Manually I can shift thru 1,2 and 3 as well as reverse. But it won't automatically shift and slips above 2000 revs when in drive. I've taken it to a transmission shop and they said the transmission itself was all clear and that I have a wiring problem. When using an older snap on code reader on the obd2 I can see the VSS and TPS reading clearly. I can also see the solenoids clicking on and off. Any ideas on how to fix this would be much appreciated.
Old Mar 14, 2023 | 03:35 PM
jetech's Avatar
Veteran: Air Force
If you are seeing the solenoids actuating the wiring and electronics should be good, right?
Old Mar 14, 2023 | 11:50 PM
bbond105's Avatar
You didn't say how many miles are on this used transmission. If you haven't yet, you should install a gauge and check line pressure.
Old Mar 18, 2023 | 05:36 PM
michaelvp's Avatar
Did you also install the pcm and wiring from the 2000 to the 1986? don't see how anything would work electronically unless you did.
