Swap 6 speed to automatic transmission
Old Mar 20, 2023 | 12:38 PM
JustinMay325's Avatar
Default Swap 6 speed to automatic transmission
95 TransAm, wanting to switch a the manual to Auto trans for bracket racing.
I've seen all kinds of post of people doing the opposite. My question is what all needs to be done to do so. Read somewhere that the trans is electric and would have to be reprogrammed with a computer??
Old Mar 20, 2023 | 01:11 PM
MaroonMonsterLS1's Avatar
Which trans do you want to swap to?
Old Mar 20, 2023 | 05:23 PM
Not sure yet. Just more curious on how hard it is do or even if its worth doing.
Old Mar 20, 2023 | 05:27 PM
2 spd (powerglide)=easy
10 spd=not at all easy
pick a number of speeds anywhere between there and it's basically a sliding scale of difficulty and cost
Old Mar 20, 2023 | 05:38 PM
Most definitely Probably go with 2 spd powerglide.
Old Mar 20, 2023 | 09:12 PM
vorteciroc's Avatar
Do NOT ever pick (GM) Number 8!
Old Mar 21, 2023 | 08:05 AM
Can switch to the stock auto transmission without having to do anything else?
Old Mar 21, 2023 | 08:25 AM
Wiring harness change
mount
shifter
center console
neutral safety switch
pcm calibration
flexplate
converter
?driveshaft? not sure if they are same length t56 vs 4l60e
pedals (unless you want to leave an unused clutch pedal in the car)
etc
it's not any small change
if you're a serious enough bracket racer you likely already know the 4l60e is not the most popular bracket racer transmission
Old Mar 21, 2023 | 08:51 AM
mount
shifter
center console
pcm calibration
flexplate
converter
etc
what's pcm calibration?
Old Mar 21, 2023 | 05:01 PM
bbond105's Avatar
If you use an electronically controlled transmission. The transmission wiring harness will have to be wired into the PCM and then that PCM will have to be tuned/calibrated to operate that transmission.
If you use a non-electronically controlled transmission. You would only need to wire in a park/neutral switch and the PCM would not have to tuned/calibrated for the transmission.
