Wave plates 4l80
I saw on another forum where a guy was having an issue getting clearance on a fwd stack and it was suggested to do that in that order.
Also on the intermediate - did the early units come without a wave plate in the stack that anyone knows about? This is a unit out of a motor home chassis that weighs more than 16k as it has the parking pawl removed and has straight cut planets on the output. Mine doesn't have the intermediate wave and am wondering if I should go thru the trouble of installing one and since i have .073" clearance should I try go get it tighter or leave it ( unit is going back in a 12k pound motorhome behind an 8.1vortec) . The unit shifted fine and nothing harsh or ill mannered before I yanked it out.
Chapelle Show classic
They should all come with a wave
.073 is too loose
always best to have the wave against the piston and a flat steel on top of the wave
I'd install a wave in that setup yes
It has the early piston that is higher so the steel sits flat on the piston and not on the snap ring so it was set up to not run it
Drives you crazy with these engineering changes ( or cost cutting?) One would think they know this is a trans going into something heavy so they delete small pieces here and there that overall can help the thing live such as these wave plates and also the silencer ring which was also missing
Only the very early 4L80E's got the silencer ring put in them. I believe that many changes got made as cost savings measures. save $1 per unit, save the company millions! Probably like the silencer ring. eliminating it won't cause the transmission to fail under warranty, However it may cause it to be a shorter life span and need rebuild sooner, hey who cares it made it out of warranty...
I read that the early units without the wave plates had a really small intermediate feed orifice and should be drill to .093 - I am assuming this is on the separator plate and if so does anyone have a diagram as I cannot seem to find it
Just surprised they kept the bevel plates in the direct and fwd but not the intermediate and these things obviously were spec'ed out and built for the P32 and larger motor home chassis with removing the parking brake and the straight cut planets.
My braked rev manual vb 350 behind the 388 in my vega does that unsettling reverse "boom" - next trip inside I am going to put the waves back as it is only 525 hp street car.
https://www.youtube.com/watch?v=fKIwj1TQmFs
I just assumed it was added later on the intermediate? 🤔
The early cushion plates are more like dished-looking than wavy-looking.
It seems they did go back to a wave in the intermediate after 96
I did a 95 build and ditched the early wave in the direct completely and used a TH400 thick wave 34127 (.060) in the forward because it's better than using one of those thinner forward 4L80E waves that can get stuck in the grooves of the drum.
Stall speed certainly impacts shift feel.
It looks like the molded steel pistons sit a little higher and appears there is no way any steel will get low enough to get into that clean out groove.
I was trying to locate where exactly is the intermediate feed orifice (if it is on the plate or elsewhere) Clinebarger on another board mentioned about opening it up to .093 if you are converting from factory non wave to wave as they left it really small.
