Firmer 2-3 shift
I'm looking for a firmer 2-3 shift. What do you guys end up doing for that? Usually a single cab silverado with a circle d 3600 stall or bigger is the application, 350-500rwhp
At the moment i do basic mods,
fitzall afl valve
vette servo
transgo hd2 kit, .500 boost valve, no shims on 1-2 accumulator, block 3-2 valve with the purple spring they provide, use that spring on AFL, iso conv valve.
Block 4th accumulator, just jam a checkball in there. Leave piston out.
Raybestos band, clearance usually 60 thou
Stock pump slide spring, stock rings
3-4 clearance .030"
check for leaks on input, i fix if they do leak.
Sonnax o ring bore plugs
upgraded bw sprag
2-3 feed hole .125"
1-2 .092
4th gear .125
br .092
Don't touch afl hole,
This is all on trans go plate
what are you guys doing to firm up that 2-3 shift? It shifts fine, but I guess I'm used to 80es and th400s that I can really feel the 2-3 shift.
They shift plenty fast like I mentioned, but its a soft feel. No flaring either.
I tune for a living so rule that tuning part out.
I drill the 2-3 shift feed hole to .155" with a 3600 stall or bigger convertor.
I don't think you will ever get it to feel like a th400 or 4L80e.
Only other things I can think of is sonnax 2nd servo will give a little less 3rd accumulation or and not real fond the superior pancake style 2nd servo pretty much eliminates 3rd accumulation. I only use the .092 on the 2-3 and it plenty firm enough for me with a vette servo and a 2800 stall. Note if you use the superior second servo with sonnax 4th servo you will need to replace to gold washer with one of the stock washers from under the pin clip else you will have an interference issue as band wears. But reality the superior second servo with no accumulation is about the only big change I think you could do to get anywhere close to where you want, again not a fan of it very clunky feeling in normal driving on the 2-3 3-2
Older Chrysler's like the 727, 904, A500 A518/618 never used a VB gasket and got away with it. How many thousand did they produce and didn't use a gasket. Wet stone the VB, Plate & Case and they are good to go...
