700r4 -4l60e pump
I started doing this years ago . Eliminated trying to find sizes for center boost valves. Give nice smooth throttle pressure with TV cable pull. Ads pressure control back to manual 1 and 2 and of course eliminate increasingly hard to find decent 700r4 pumps.(you can actually use later 4L60E pumps too as long as early stator)
Works super well and yes forward accum still works and presure with a sonnax or transgo .500 boost valve runs at about 60 psi at idle and 220 at WOT with a nice smooth transition.
Just putting something out there for opinions and discussion. Keep forum active
Other added advantage allows use of deep 4L60E pan and filter.
Will this method work with a transgo sk700 shift kit? Transmission I'm working on has the kit in it already
You're welcome. I generally try and use the early 4l60e pump but you can use any short stator oring pump. I have literally done 100s like this never an issue .
You probably already know how I know all this BEEN THERE DONE THAT.
Basically, I figure this out because at my former employer we were having issues finding decent 700 pumps and good middle boost valve sizes, This was the solution I came up with , Worked awesome with added advantage or being able to use 4l60e filter and deep pain.
Just don't forget drill forward feed hole pump to case it is missing in late cases, Block Tube feed to accumulator hole in aux VB Cup plug works well. Leave out ball in aux body, replace fwd accum spring with 4l60e 4th accum spring . You will be golden as they say . Any 4L60E pump with oring seal will work, But I generally use early styes 93 to 97 no sense in wasting the crowned later pumps. And the early pumps are generally cheaper. PWM or NOT does not matter.
Anyway, I have never tried this...
But it is VERY INTERESTING and VERY INGENUITIVE!!!
Truly AWESOME!!!
I will have to PM you and get into some more Details with you!
HOWEVER!
I have to ask...
Regarding 1982 - 1986 Models (Pump has a 0.0950" Feed Hole between the Sealing-Rings on Rear of the Stator Support Tube)...
The Reverse Input Clutch essentially has no Feed Restriction when using the 4L60E Pump.
Do you have any Harsh Reverse Engagement?
The 1993 THM700-R4 also had essentially the same configuration:
-No 0.0950" Orifice in the Reverse Input Drum.
-No 0.0950" Orifice in the Pump between the Sealing-Rings on Rear of the Stator Support Tube.
So the Feed Hole in the Valve-Body Separator Plate got a Check-Ball installed over it...
And a 0.0950" Orifice was added next to it.
The 1982 - 1986 Valve-Bodies do not have a Pocket to accommodate a Check-Ball, But...
The Separator Plate Feed Hole could be Plugged, and the 0.0950" Orifice added.
I believe there would be enough exhaust available via the Pump (exhaust there for the Reverse Boost Valve).
To have the D4 Passage that the 1982 - 1986 Cores had (removed in later Cores due to D4 Pipe being used for the added Auxiliary Valve-Body).
Obviously the 4L60E Pump does not accommodate the Pipe, but does accommodate the 1982 - 1986 Passage for D4 Fluid.
What is the "2nd feed at top right square hole in case" ?
Would you rather just discuss this via PM?
I would understand if you did!
[/QUOTE]I have not noted either personally nor from customers of any issues with it being excessive. (Note all PB 700r4 the last near decade were done this way) Note the first couple were harsh as I failed to think through removal of the check ball in aux body and was still using stock spring but once that was delt with no issues,
The presure boost in reverse at idle is much lower but rises quickly with throttle I do add the wave plate to the early units.
As for forward engagement early units pre aux you really do nothing but use the pump and Block the feed on case top right its square with round hole aux units but just round in early units .
In aux units drill feed from pump to case, block square hole with round center at right front of case 1/4 check ball works perfect , Plug the tube feed hole in the aux. a 10mm ball like in the tv slot works well, Leave ball out of the aux VB or it will block feed to accum, replace accum spring with 4th gear accum spring from 4l60e.
RESULTS
1-Very nice smooth TV line rise with throttle with .500 boost valve you will see arround 200 PSI max but I add a small spring in boost valve this jumps it to about 220 max.. Idle PSI 60 to 80 typically
2- Normal Line rise in manual 1 and 2 same as d3 and d4 instead of max line .
3- The ability to use a stock deep 4l60e filter and pan No extenders or adapters
4- And best you are no longer dealing with 2 boost systems, sizes and valves
5- You can use any o ring seal style 4l60e pump from any year 93 to 2006 much easier to come by than good 700-r4 pumps
Frank
https://ls1tech.com/forums/automatic...l#post20503877
Facebook Post
Note this is at 1800 RPM
