4L60E EPC solenoid
Does anyone remember off hand?
On this site: https://go4trans.com/technical-trans...cy-duty-cycle/
Your answer is 585.
Frankly I had no idea the EPC was PWM. I thought "PWM" on the trans referred to the lockup solenoid.
Always good to learn new stuff.
Your answer is 585.
The TCC has both an on off solenoid and a PWM solenoid. The PWM is usually disabled by modifying that portion of the system. People either block it, use a TransGo SK, a Fitzall blocker valve or a Sonnax valve. Then that PWM solenoid is just there to supply an Ohms reading to the PCM.
As for the EPC
They did change the frequency, but I have interchanged these solenoids with no ill effects.
I have used the early EPC in a late trans.
And a late EPC in an early trans.
Have not had any failures, codes, etc
I am adding a way to control the EPC solenoid to my stand alone shift box. I just wanted to set the hertz to the proper frequency. I also know it runs 1.1 amp low pressure to .1amp high pressure. It's the HZ & duty cycle that I have to set up in the control box. The duty cycle runs @ +5% for minimum pressure & +40% for maximum pressure. The information I have doesn't elude to the current HZ that they run at. If I am not mistaken they only used the 292.5hz in the prom chipped PCM's and all the newer one's used the 585hz and I cannot say if it really truly matters or not.
Here's why I like the box. When I get a customer complaint about shift quality & function. I can go slap the box on & show them it's the car/tune and not my transmission. Showing them speaks so loud that everything they say becomes null & void...
I built my own box 20 years ago but could only operate at full line and I just don't like that. Using a scan tool serves the same purpose. It just doesn't have the same impact to the customer. The box is an in your face disconnect from their car. The box uses the accessory plug for power and ground I also have a battery connect extension for inactive accessory plugs.
Next will be the control of the TCC solenoid for the 4L80E.
