Build pics level 2 heavy duty
Old Sep 4, 2023 | 05:35 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Default Build pics level 2 heavy duty
CUSTOM TOP PLATE I MAKE IN LATHE
BETTER THAN SONAX LONER STIFFER SPRINGS LESS PRONE TO HEAT DAMAGE
NOTE HOW RIDGE ACTS TO HELP REATIN CLIP
TH350 STATOR BUSHING
OVERUN MOD NEW PLATE
MODIFIED QUICKER 2-3 SHIFT VALVE AND SPRING
NEW PAN ALL UNITS ECEPT STOCK OR LOW BUDGET BUILDS
__________________
Old Sep 4, 2023 | 06:08 PM
sjsingle1's Avatar
great pics ! so what springs do you use at the top of the 3-4 ? and does the shift valve need a spring on the end ?
seems all the builders use the ...level XXXX it their description of what they build....what describer do you use in your builds and what do they encompass ?
Old Sep 4, 2023 | 08:43 PM
LS1Tech Sponsor
I can only make comparisons to PerformaBuilts units as I was the guy who came up with the builds, they USE but I would say this build is just above the level 2 but has some attributes of the level 3 and black editions and some mods none of them have. If I was going to give it a power rating which as we all know is subjective dependent on weight, type power adders, rear ratio etc. , I would say 700 rwhp for a general guide,
The springs commonly available actually HILLMAN 540006 Perfect snap in fit to replace stock springs with higher spring rate and a little taller and stiffer but stand heat really well. I have seen these where the EPC/PCS has failed and the 3-4 clutch cook. They will be black but springy as ever. I found them years back looking for an easy readily available replacement for the stock springs did some Test and been using them ever since.
The spring on the 2-3 valve first came up with it years ago noted very noticeable change rate from 2-3 solenoid off to actual change on Dyno though the dyno did not have an actual way to make a measurement and in my own car which i have the best knowledge of my 2-3 shift time data logged with it at WOT is .200ms quicker than my 1-2 command to actual shift, this is opposite to what would normally be expected. With these mods 3-4 failures for me in these units became virtually nonexistent without some outside issue like PCS failure or other pressure related failure.
Beyond that the photos are mostly self-explanatory other than I do make the the top plate for the 3-4 using a stock thick plate machining it like this makes more room in that pack without hurting the strength of the plate avoiding warpage Then I use the alto power pack 9 friction with it but change out the ultra thin steels it comes with for the next thickness up I think .073 I would have to check but as you can see they are Thicker than the friction plates.
All my builds except for what I call the budget build come with a new pan as it makes little sense to buy a used pan and paint it all in having like 20 dollars in it when for 20 more you can get a new heavy duty stock style pan from Dorman with a removable drain plug.
And all my builds again with exception of what i call the budget build come with a NEW Reverse input drum. Budget gets a machined one on lathe.
This build has all the following-
1-CARBON FRICTIONS
2-NEW STEELS
3- NEW SHIFT SOLINOIDS
4-NEW PCS
5- NEW HARNESS
6-RAYBESTOR PRO SERIES WIDE BAND
7- NEW REVERSE INPUT DRUM
8-BORG 29 ELEMENT INPUT SPRAG
9--NEW BORG ROLLER CLUCTH LR
10-BEAST REAL BEAST SUNSHELL
11-.500 BOOST VALVE
12-NEW BUSHINGS AND EXTRAS ADDED A COUPLE SPOTS
13-NEW SEALS RINGS ETC
14 -CORVETTE SERVO WITH NEW PIN
15 DUAL PISTON OVERDIVE SERVO OR SUPERIOR SERVO DEPENDING ON AVAILABILITY. I DO NOT HAVE A PREFERENCE THOUGH I DO TRY AND STAY WITH THE SONNAX DUAL SERVO IN TOWING APLLICATIONS LIKE THIS ONE WILL BE.AND AFTER LOOKING AT RESULTS OVER YEARS STILL PREFER THE TEFLON RINGS ON THE SECOND OVER D RINGS. SQUARE RINGS ETC I HAVE SEEN.
16-SOMETHING I CALL THE FULL TIME OVERUN MOD I CAME UP WITH MANY YEARS AGO WHICH KEEPS THE OVERUN CLUTCH ON IN ALL GEARS EXCEPT 4TH EVEN IN D 4 POSITION THIS ELIMINATES SPRAG ROLL (Others have also come up with various ways to do this I have my own method) It is also shown in photos.
Sorry for the caps lock but not going to retype all of that I was not watching and didn't realize they were on, But this highlights the build. I have additional things I do also mod wise but this covers most of the main items the others are about hydraulic integrity.
For anyone interested this build runs about 2600 shipped to your door 48 states no core required, for 2007 up add 200 cores cost more, or bring yours to me in Berwick PA and save 100s on any year.
Frank
__________________
Old Sep 5, 2023 | 12:51 AM
sjsingle1's Avatar
do you paint the cases or media blast them ?
Old Sep 5, 2023 | 10:17 AM
LS1Tech Sponsor
MEDIA (SODA) As its water soluble don't care for sand, nuts, glass as the get embedded and stuck in things but also in addition paint since being in the north the salt so badly discolors the aluminum while smooth after blasting, they are still rather ugly, So they get a light coating of VHT exhaust hi temp enamel. I first heat the case to 200f to get any moisture out then let it cool to about 120f then paint then heat back up to 180f makes the finish fast and firm.
__________________
Old Sep 5, 2023 | 05:32 PM
Edward Stark's Avatar
Watching mr. Frank build a tranny is like watching god creating earth. This is so epic and rare moment.
Thank you for the tip on the return springs in the 3/4 drum.
If i was in the US, i would def get a unit from you my man but the problem is where i live, the shipping will cost 3x more than the tranny itself and customs payment around 1000$ So lucky people who can order from you who lives in the US / Canada.
1. I noticed your checkballs are plugged. The ones that 2 together. Do you mind describing what it does, if its not a secret? Thanks!
2. When upgrading the servo and drilling the 3rd feed to like 0.135", I always hear a clunk in part throttle only when 3rd engages. Like from 2nd to 3rd there is a clunk, or in a downshift from 4th to 3rd. How you get rid of that?
3. Do you use 0.020" clutch clearance or 0.030'?
Anyways, there are legends about Performabuilt's unique Valve body mods and a big shadow on how its done. It's good to know that mr Frank came with all of this upgrades alone.
Good luck in what you do my man!
Old Sep 5, 2023 | 06:26 PM
LS1Tech Sponsor
1-Its part of what I call the overrun mod, it keeps the overrun clutch on in all gears except 4h even when in the OD position on shifter, This helps support the input sprag.
2-Never really feel a clucnk maybe a hold back as it downshifts to 3 from 4 but their is a notable downshift feel on the 3-2 many mistake for the 2-1 but 2-1 would only happen if I had the low/rev clutch mod added Which in this build I do not. A little semi clunky feel on the light throttle 2-3 with wide bands large servos is just part of a performance unit if you look at tuning even GM did a pressure pull back to try and quell that.
3- My dry clearance is .020 before adding the return springs which generally adds about another .010 so final is arround .030 and will generally as I noted for years with the Dyno will open up another .010 arround after a few max line applies.so ultimately you end up arround .040
4-My valve bodies have always been unique in the way I accomplish things compared to others and will continue to be as I AM ALWAYS INTERESTED in MAKING THE UNITS BETTER and introducing new and better units .
Thanks Frank
__________________
Old Sep 5, 2023 | 07:06 PM
dixiebandit69's Avatar
I thought you were supposed to leave those springs out on any sort of high performance/ heavy duty build.
I left them out on my build.
Old Sep 5, 2023 | 07:55 PM
LS1Tech Sponsor
No. I would not leave them out, I mean you are probably ok. But they help avoid hot spots on steels. Provide some cushion for the drum in ring area and little if any effect on shift while also helping avoid centrifugal apply in 1st and 2nd at high RPM along with revving in neutral or park.
__________________
Old Sep 6, 2023 | 12:33 AM
sjsingle1's Avatar
the ATSG manuals do say to leave out those springs....now we know better
Old Sep 6, 2023 | 09:15 AM
LS1Tech Sponsor
I think it was more about the springs are usually trashed by the time of a rebuild and used to be hard to get. Also the stock springs are virtually useless for anything but a stock layout and stack height of clutches they are just too short. Sonnax makes some longer than stock and they are fine a little pricey for what they are, These I have work perfectly better IMO and are cheap and easy to get at 1 dollar each at any ace hardware.
__________________
Old Sep 6, 2023 | 09:20 AM
LS1Tech Sponsor
Note this group of pics was not done just for this post, every unit I do gets a full pictorial for each customer this is just one group of them.
I feel this helps build Trust and transparency with the customer, they see and know exactly what they are getting.
__________________
Old Sep 6, 2023 | 11:23 AM
MaroonMonsterLS1's Avatar
There is AFL pressure on this end of the valve where you've added a spring
Appears the end of the valve has been turned a wee bit to give a stub to center the spring on?
I've found that just a proper AFL with increased base seems to work well and is less trouble than the spring.
Care to elaborate on your thought process here
Old Sep 6, 2023 | 11:46 AM
LS1Tech Sponsor
Just a helper, I first did it years ago and noted the shift seems to happen quicker on the Dyno but no real way to measure short of feel observation since it had no method to measure this, but later in my car noted that the 2-3 shift time became shorter than the 1-2 opposite of previous observation so I incorporated it into the build also after this was added the people calling saying with equal settings on the 1-2 and 2-3 shifts the 2-3 took more RPM command to finish time so had to allow more time to complete shift stopped in fact a number of others I spoke to noted the same in data log the 2-3 time actually became quicker than the 1-2 command to actual shift...
And yes I machine the valve to accommodate it, the little spring is actually pretty stiff. So far I only have data log stuff to verify this. Someday I would love to get it on a more advanced real dyno to see a before after measurement. I do know since it's been in use in the levels 3 and black edition for years now at my former work it caused no issue and the numbers show a lower 3-4 failure rate anything to make these come on faster as they do not like heat so moving that valve quicker has to be a plus. I also experimented with enlarging the orifice hole in the solenoid but was not confident enough to ever try to put in service but it did function ok. In a couple test on the dyno.
I am sure several methods could be used to accomplish the end goal including restricting the oil to the solenoid for quicker exhaust though I worried this might affect kickdown time more but the modified valve and spring is where I landed.
The Initial goal was to quicken the 2-3 shift time without overly enlarging the feed and changing the release apply dynamics of the band and 3-4 clutch. Ultimately.
__________________
Old Sep 6, 2023 | 12:41 PM
Ever had issues with upsetting the valve balance?
Too much spring on that end and/or a leaky valve/solenoid could lead to the valve not being able to downshift
Also, the improvement here would be the time between a solenoid OFF command and the actual valve movement, it won't affect the physical time between valve motion and the shift happenings. The orifice sizing on the 3/4 clutch feed and the 3rd accum will still determine the shift characteristics.
I've experimented with a spring on the end (I drilled the valve and used an accumulator spring in the pocket)
And have experimented with solenoid orifice sizing in the solenoid itself.
Never noticed anything significant enough to continue it, but it's neat to hear someone else having different results with similar experiement!
Sounds like you have lots of units out there with no ill effects, so cheers to that
Experiment with the land width on the middle small land and let me know what you find That has some interesting results as well.
Old Sep 6, 2023 | 01:03 PM
LS1Tech Sponsor
No issue on downshift if anything maybe delayed a little on a coast stop but that with the overrun mod is not necessarily a bad thing avoiding so much of a feel with the 3-2 and overrun on.
Unfortunately, at least for now no DYNO to test things and no lift to use my car for it. I do have a dyno plan in the works with twin DC motors and variable speed 500 to 5000 rpm and other functions but time and money will determine when that happens. Of course, a real Dyno is cost prohibitive in my position. So for now other than things I know will work no experimentation Though I do think room for more always exists and I do like seeing the various different ways people get to the same results.
Primarily My task back then was to improve the unit while spending none or as little money as possible while simultaneously keep up with and helping keeping up with customer demand by building. When things finally came to a point that was not necessary it was basically decided my knowledge. loyalty, contribution without that did not have significant enough value to justify my earnings. But enough of that still a bit of a sore spot but it is as it is.
__________________
Old Sep 17, 2024 | 08:47 PM
Redkeys's Avatar
Hi Frank would so kind and give us the part number for these spring at ace hardware?
Old Sep 17, 2024 | 09:04 PM
LS1Tech Sponsor
Hillman 540006 #2 spring 1-1/4 l 7.32 dia. .032 wire gauge
__________________
Old Sep 17, 2024 | 09:06 PM
Redkeys's Avatar
Thank you!
