4l60e complete upgrade discussion
An example of this is just a few days ago Frank posted some pics of his work, and I noticed something that I hadn't seen before. I asked Frank a few questions and you can bet I copied the pic and his answers to my document.
Most of the time a build list like Franks, Bbond105's or such is where you can start. The build list is what part's is best to use for their business. The how/what to do is for you to supply. For example I use a builders bench stone on all flat surfaces. The fine side on the case/valve-body/pump bodies/pump covers. I even use the course side on the separator plate. It smooths out any high spots and actually allows 99% reuse of the plate with an oversized 1-2 check-ball. The TransGo SK's come with a .265 gold ball and the AXOD/AX4N ball is .312. I also scotch-bright all accumulator/servo bores. I no longer scuff steel plates or drums. It's been proven over time to be a detriment to shift quality. There are times that certain drums need to be scuffed or sanded for garage shift feel, like the 2nd drum in a 4T60E/4T65E for the reverse band.
Some research and time spent building your own spec sheet is best.
here is my own stage 1& stage 2 build lists. I hope this helps...
Stage 1 400 Plus HP/400Lbs. Ft. Torque
· Gasket and seal kit
· Allomatic or Raybestos Filter
· Raybestos GPZ 2-4 band
· Complete friction kit w/7 Raybestos GPZ 105 4L65E 3-4 frictions/ 6 .095 3-4 steels
o 4 B/W Reverse input
o 5 B/W Forward’s
o 2 B/W Overruns
o 5 B/W Low/Reverse
· Essential bushing kit, with wide or Teflon bushings where applicable
· Oversized pressure regulator valve
· New EPC solenoid
· New Shift solenoids
· B/W 29 element dual cage input sprag
· B/W 4L65E Low roller element
· Hardened reaction sun shell
· Aluminum Accumulators
· Corvette servo
· Long servo pin
· .500 boost valve
· Sealed Power Hardened pump rings
· TransGo shift kit
· 1-2, 3-4 & forward aluminum accumulator pistons
· Vacuum test valve body (repair leaks in 3-4 circuit as needed)
Stage 2 to 500HP
- 74002E 93-2003 or 74002GA 2004-up Gasket and seal kit
- A74010EC 96-2003 or A74010ED 2004-up deep pan filter
- A74020BAHK Raybestos GPZ 2-5/8” wide 2-4 band or N74020BHP Alto red eagle wide band
- 74119BS1 Complete Raybestos Stage 1 w/8 Raybestos frictions.
- 7) 74120A .077 steels, 1) 74120B .060 steel if needed for proper pack clearance. (Place at top of pack for heat dissipation)
- Necessary other steels
- Essential bushing kit, 74034B, 44036B, 74037A, DB74046A, DB74056B, 74064 with wide or Teflon bushings where applicable
- S74507PE-1 Oversized pressure regulator valve
- A74658C B/W 29 element Input sprag
- A74654A B/W 4L65E Low roller element
- D34435B(93-02) or D74435B(03 & up) New EPC solenoid
- D74421 New Shift solenoids
- D74908C long 2-4 apply pin
- A74624B Hardened reaction sun shell
- 74556B Rev. input drum
- A74927, A74927A, A74927BA Aluminum Accumulators
- A74905BK Corvette servo
- T74171E TransGo shift kit. (allows holding 1st to any RPM)[eBay USA ind. saves $$]
- T74165HP No yo-yo pump ring kit
- S74902H Sonnax 4th super servo
- S74741S-1A Sonnax HD 3-2 shift valve (applies Overrun frictions in 3rd,2nd & 1st.
- Vacuum test valve body (repair leaks in 3-4 circuit as needed)
o 5 B/W Forward’s
o 2 B/W Overruns
o 5 B/W Low/Reverse
· New EPC solenoid
· Corvette servo
· Long servo pin
· .500 boost valve
· TransGo shift kit
Stage 2 to 500HP
It's all available in our Search Engine...
The Google Search Engine most often pulls from our Search Results on 4L60E Builds.
The majority of the Build Information has been the same for years and years.
However there are always small details that change with time.
Fads come and go, New Parts come out, some stay, some go...
I was going to cover a Build in a really big Thread...
I started it (It's now a Sticky) and anyone with experience (There are Many here) can add to it/ continue it!
I am not up to working on it at this time but hope to be able to in the future!
Personally I use .092 for 2nd and .100 for 3rd and 4th
Also here is a simple mod I do . Other ways exist to do it but this is easiest IMO I call it the FULL TIME OVERUN MOD its pictured , Please excuse i have not cleaned up the connection channel in this photo but it shows clearly how to do it and its simple, The purpsoe keep the overun clutch on in all forward grears except actual 4th to help reduce shock to and support the input sprag, And yes you then leave the ball out of the bathtube
full time overun mod
I at one time was considering making a sprag slug out of solid aluminum or steel and just using same circut to just release the FWD clutch like Ford does with the AOD and 4R70W and eliminating the sprag but was afraid might be to hard to time it and not end up real clunky on the 3-4 4-3 shifts.
No one shared this info before.
Only Vorteciroc and Maroon challenged everyone to figure this out and no one did.
What is the purpose plugging the holes? Is it nessesary?
Mr Frank, first, i want to thank you
Second, you just killed an expensive Sonnax HD Valve
I also have a mod that turns on the low/rev clutch in D3 1st gear but its a bit more complicated and not really needed except in extreme cases, For instance had a vet that kept shattering the low roller on launch years ago 900rwhp using the low roller mod solved this and other than that only a couple other cases.
But mods I post here and hope others do to I want to be simple stuff easy and free or low cost.
Some worry that people will build their own and not buy from vendors if they post to much but I have found those that are gonna try it on there own are gonna do it ether way and honestly most first timers are going to fail I have noted as many many build post here show, But On the other hand I have had a number of those people to in the end come arround and just buy one from ME/US AT THE TIME. So I really do not think its such a problem.
One of the reasons I have never had issue with helping those who built their own or bought from others solve issues sometimes even when frowned upon by people over me because it has on a number of ocassions resulted in a sale of a unit either for the one they failed at building or had trouble with or in more cases after dealing with me they felt it easier to just buy the unit from me or through me to avoid the headaches.
I'm already busy enough! I don't need to gate keep every little thing to try to keep someone else from building. I don't have time to take on all those builds anyway!
The home shop guy can use some of these tips and tricks to build his own reliable unit. And I think that's great.
I think we all have some stuff we've developed or worked hard on that we don't want to just give away (for example I'm not going to do a write up on how to design a transbrake for the 4l60e or how to do my reverse input clutch on in 3rd gear setup etc...that's some complicated stuff that took development time) but tricks on assembly, stuff like the overrun mod, etc
All that is well worth sharing. And it has the added benefit of "pulling back the curtain" a bit. It shows customers or just interested parties that we are doing more (and understand more of the complexities) vs just buying a transgo kit and an overhaul kit and slapping it together.
One tidbit I'll add here is that for high performance units, or especially for towing units that will see repeated 4-3-4-3 shifts, I find it beneficial to drill a .025 hole (yes it's tiny and difficult to drill) in the case. 2nd clutch oil to left of the anchor.
When aimed properly, it's a tiny hole that won't hurt 2nd apply, but it will provide lots of cooling/lubricating oil to the rev drum right in the gap between the ends of the band. This helps keep things cool so you don't burn up bands on repeated 4-3-4-3 shifts towing or heavy throttle shifts into 4th.
But IMO well worth it as I worry that not just shifting but crusing while towing in OD presure can be realitively low and the band IMO can slip some , The mod helps to keep it cool when this happens.
I was actually thinking at one point of an orificed feed of 3-4 clutch oil to the boost valve to slightly raise line slightly when in 3rd and 4th without changing shift firmness to any degree but would take some experementation and dyno time or in car getting the orifice size just right but never got the time or interest to work with it. I mean the same could be done in tuning of course but thsi was more for the towing crowd who unlike the performance guys are much less likely to do or have any tuning done.
(those who wonder why I use bold type no reason other than I find it easir to read lol guess im old. )
And the Manual has some issues, Such as it will tell you the Overun clutch is on and 1-2 in d3 2 or 1, It is not , Its only on in D3 3rd gear not in 1-2 manually or automatically.
