1996 Tahoe 4L60 to 2006 5.3 engine, flywheel kit?
Use one of the flexplate pilot spacers(this is the most usef type ) the stock 06 dished flexplate for a 4l60e, and you will have to elongate the holes about an 1/8" in as the 298mm tc has a slightly smaller bolt circle mounting pattern.
The following users liked this post:
cammag (02-20-2024)
