4L70E no TCC lockup
I know the O-ring on the shaft is good and new, I replaced the factory TCC valve with the TransGo unit that has a screw in it and has to be pushed in and out per instructions. Replaced the boost valve in the pump and all the other parts that were included in the kit. I replaced all the solenoids in the transmission with the exception of the TCC solenoid that is hardwired into the harness as I re-used that.
With the vehicle off and the key on, using the Scanner, when I command shift solenoids A and B I can hear them click, but when I command the TCC I cannot hear anything. Is that normal?
There is a very small orifice in the pump that supplies TCC solenoid with signal oil off the converter feed circuit.
If that orifice has debris in it and is plugged you will have a no lockup symptom
I'd verify the TCC reg valve isn't sticky. and the TCC Control valve in the pump is also freemoving.
Another diagnostic you can do is to put a checkball in the snout of the TCC solenoid. This will block it closed (same as if solenoid was ON)
When you start the vehicle it will idle in park/neutral
If you put it in gear, if the converter is locked, it should stall the engine.
This isn't the best for the converter so it wouldn't be my first recommendation.
If it does pass the test I'll proceed with the suggestions you have posted above.
Thanks!
Bow i have firm amd positive lockup. Just wanted to update with the solution.
