4l60e TCC vs TCC PWM
I don't think so, on you last question, but not for sure. If the PWM solenoid was bad, it will likely set a code (?)
It's my understanding that the PWM function is to smooth out TCC operating and eliminate shudder.
Based on that, I'd say it's TCC applying, but there are many things that could affect that.
(which primary naptha) and then changed the fluid again by sucking it out of the dipstick. It shifts well now but it shudders on occasion under light steady throttle at slow speeds. I don’t think the transmission or TC are going bad due to being “beaten on,” but from varnish and such from sitting. I need to change the filter but I’m thinking about replacing the TCC solenoid and maybe the PWM while the pan is off.
Second, most of that sh*t is still in there if you only ducked the fluid out of the pan. That only gets 3-4 quarts IF you're lucky.
Change it again, and change the filter.
Last, I'm pretty sure that PWM wasn't used until at least '04, but I might be wrong, and it would depend on the application.
Ex: the transmission I used in my swap said PWM on it, but the valve body was not PWM compliant. (Out of an '04 Tahoe.)
Maybe someone knows if the 4l60e from ‘00 has both a TCC and a TCC PWM solenoid. I googled diagrams and they showed both.
I would try lubegaurd shudder fix . I unussualy dont promote snake oils but it did work in my escort stationwagon when i dd trans all was great except a rumble shudder on TCC apply . I took a chance and bought a bottle its worked ever since, Also if a new converter it is possible wrong converter clutch material.
It took several bottles of PEA laden injector cleaners to fix a surging idle issue. This thing was a sitter (outside I think) and it has sitter issues I’m afraid. Other online reads say that the TCC solenoid can cause shudder at lockup. Is this not the case? Can nothing in the valve body (valves, solenoids) cause TC shudder?
