Having issues with my transmission after having my engine replaced
So my engine blew and I took it to a shop and had them put in another engine, this was just 3 weeks ago and today while driving it just stopped working. Had it taken back to the same shop and they said the transmission pump is broken, my question is how could this have happened? Did they mess something up when they replaced the motor and are they liable for the transmission pump or am I just screwed and have to buy a new pump and labor to have it installed? Appreciate any response
They almost certainly ruined the pump by being sloppy with the torque converter. Either they removed it completely and didn't re-install correctly, or it came out partially and they just forced it back in.
I'm 99+ % sure it was their fault.
Thank you for the response and info! 😎
Sounds about right! Thanks for the response, going to call them in the morning and if they don't own up to it I'll take your advice and go to a different shop.
How many miles on the trans? If it has many miles, its a slippery slope from just opening it to needing a complete rebuild. For example, removing the pump might/likely tear the sealing rings on the input shaft; and so on.
If the original shop won't admit to their mistake, give them bad Google and Yelp reviews, complain to BBB and look up how to file a small claims court. They might decide it better long term to pay for a trans rebuild. If they do, remove the bad reviews. I think that the forum rules allow you to mention their name and city here too, just not complete contact info.
Precisely why I pay everything with a credit card. I recently had a transmission issue immediately after putting my new engine in. gave the car to a tranny shop to look every wire, harness, plug, etc on the outside oveer to see if they see anything before they open it up to swap parts. Well they opened it up, swapped both shift solenoids and the problem was still there. They charged me $300.00 to drop the pan, swap the solenoids and put new fluid and gasket and filter in and bolt the pan back on.
But if they really did their job and just looked at the woring harness plug going into the tranny they clearly would have seen a ground wire pulled out of the plug end.
Towed it to another shop and they saw the wire and took a picture.
AMEX reversed charges and case closed. **** these scumbag shops that try to screw people.
If you paid the first shop by crdit card......dispute it.
Is the transmission you are referring to the one in this thread?
So. Im sure they just dropped the pan, swapped the solenoids and said they cant fix it. And figured lets charged him the $300.00 for 20 minutes of work and if it fixes it greatif not tell him we tried.
Granted, I had to ohm the wires and put them in the correct spots because every wire was pinned wrong, but that only took 20 minutes and about what I expected for $16....
Frosty
