10 speed in our 4th gen’s
Old Oct 16, 2024 | 04:07 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Originally Posted by Utinator
Oh, I agree. It sucked. I just didn't know any better at the time. I hope other people will read this and avoid the same mistake(s) I made. If I could do it over again, I would just get headers and a 3k stall for the 4L60. I would have left everything else stock. It wouldn't be fast, but it would be fun. It would have saved me lots of $$$ too.
I have spent way too much $$$$ on this car. The 6L80 sure is fun though. I wish the 6L80 was an option when I did the 4L80 swap. I probably wouldn't have done the heads/cam. I just heard way too many stories of the 4L60 coming apart to leave it in there. I wanted to make the car more reliable, so I got the 4L80. I didn't know it was gonna make the car slower. oh well. lesson learned.
When I say slow off the line, I mean 2008-ish Mustangs got 1-2 car lengths on me before I ran them down. I usually caught up to them around the 1/8 mile, and won by 1-2 car lengths. My best 60' was a 1.9 sec. That was with amazing DA, 40 degree air temps, and really good track prep. My typical 60' with the 4L80 was about 2.2 sec. I haven't had the car on the track since the 6L80 swap, but I can tell it is much quicker. It only drops about 1k rpms or less between shifts. The 4L80 dropped way more than that.
Not that it matters now, as you have swapped to a different transmission but, for the sake of conversation, if you had just swapped to a 3.73 axle ratio then 1st gear with your 4L80E would have been pretty close (9.25) to 1st gear with a 4L60E and 3.23s (9.88). That would have raised your 70mph cruising rpm to about ~2600, but that's still very reasonable IMO. That would have helped to tighten the "feel" at part throttle and launch, but the real gains would have come from moving to a 4000-4400 top shelf stall speed with that cam. Again, I would expect at least 1.6 60-foots, or better (depending on tires), with that setup and your engine combo - and shift extension (rpm drop between gears @WOT) would have been excellent at that stall speed.
I can't imagine how a stock ~2008 4.6L Mustang would be able to put 1-2 car lengths on even a completely stock LS1 4th gen at any point in the 1/4 mile, much less launch, unless you just totally blew the tires away off the line. Even with the extra weight and softer 1st gear of the 4L80E, launch should have been better with that converter. I wonder if the converter was somehow defective or the wrong stator was used for the requested stall speed?
Old Oct 16, 2024 | 05:02 PM
Utinator's Avatar
There's no way I would put a bigger gear in the rear end with the 4L80. I try to keep my highway rpms close to 2000 or less. 2600 rpms on the highway is absolutely unacceptable. With the 6L80, I'm close to 1700 rpms at 70 mph, and I get off the line much quicker. The 6L80 gives me the best of everything I want.
I don't know why I got blown away so bad with the 4L80. I think my car is just slower than most. It took every mod I have done just to run mid-12s in the 1/4 mile. Before the heads/cam, it was a consistent 13 second car in the 1/4 mile (with 4L80). That's when I was thinking about adding a Pro-Charger, but never got around to it.
Old Oct 16, 2024 | 05:08 PM
91 Z28's Avatar
Why is 2600 rpm on the highway "absolutely unacceptable" ?? Why do you want to be idling down the highway?? Idle is for the driveways and traffic lights
Old Oct 16, 2024 | 05:15 PM
RPM WS6's Avatar
I didn't realize 2600rpm would be so horrific to anyone, especially with a modern engine using a modern lubricant. I think I now understand why you felt the A6 was worth it; I guess some folks just have a much lower tolerance for cruising rpms. I'm always in the 2400-2600rpm range at highway speeds with the old 355 SBC in my '71, and that engine hasn't been rebuilt since the mid '90s. No issues at all. I guess it might bother me if I was building a daily long distance commuter and looking for every ounce of MPG - but for a toy?...no worries.
Glad the 6L80E is working well for your application.
Old Oct 19, 2024 | 02:10 PM
Utinator's Avatar
I basically built it to be a daily driver that can be drag raced as well. I don't drive it to work everyday, but when I do, it is about 26 miles one way. About 23 miles of that is highway, so yeah, the rpms are kinda important. I don't want my engine screaming down the highway that far. I like driving my car. It's not a garage queen. I also don't want to choose between a drag car and a street car. The 6L80 allows me to have both with one car. It has the better gearing to get off the line, and for cruising down the highway long distances. We used to only have the option between good off the line and weak (4L60), or slow off the line but strong (4L80). The 6L80 gives you the best of both. You don't have to decide between a drag car and a street car anymore. You can have both with one of these newer transmissions.
Old Oct 20, 2024 | 02:12 AM
RPM WS6's Avatar
4L80E + 3.73s = ~2600rpm cruising at 70mph with a 25.66" tire. That is in NO way a drag car to me, perfectly fine for the street. Back in the old days, factory BBC cars came with ~26" tires, 3.31 gears and a TH400 with no OD and no lock up. They all turned ~3,000rpm at 70mph right off the showroom floor, and engine lubricants of the day were inferior to what we have now. Nobody considered that to be drag car territory (if you wanted to drag race, you ordered the car with 4.10/4.11 or numerically higher).
I don't feel confident that a 6L80 is proven to be a "better" (i.e. more durable) unit than a 4L80E, so in my eyes there is still a trade off and I would always pick the 4L80 for a street car when the 4L60 isn't enough.
With that said, if you are in fact building a commuter and worried about MPG then yes, I do understand your goal and it's great that the 6L80 gives you everything you want.
