Tcc circuit test rig
It would need a decent frame work to support torque converters, and it would be beneficial to have a way to add rotational input to the TCC, wouldn't need to be a huge amount of power.
But then its me, if there is an easy way to do something, I'll always find the most difficult one.
But then it’s me, if there is an easy way to do something, I'll always find the most difficult one.
But I have seen some baffling things with the DYNO every so often sometimes with solutions sometimes not.
Pump half leaks or cross leaks can come into play and the lockup function itself is more complicated than many think, I tried at one time to explain to a former employer wondering why it was taking so long to solve an issue that unlike gear clutch applies , it is not as simple as a piston applies and springs release. You are working with an apply and a release side hydraulically and can have issues from either. And of course with PWM LOCKUP also spends time between not fully applied or released.
Even with issue with the valve travel and shimming. You cannot do it for all as it may cause issues and you cannot do it with same shims everytime some require a little more some a little less and too much either way you again have a problem. And the spring must go through the shim else that to can be an issue.
Of course when I tried to explain they didn't understand much more than a simple on off apply piston is involved which is why chasing an off lockup issue can feel like chasing your tail at times. Can be very frustrating. I will be curious how your rig works out.
With bolt together at least you would know what is going on inside with the input shaft etc.
Do the 4L60E's use an apply and release side to the TCC piston? Seems like a good test for the TCC internal components, input o-ring, etc. If it was a new unfilled TC I wonder if a vacuum test would show anything? It would tell more than just blowing air.
1. So far in my testing, the depth of the input shaft and stator did not have an effect until the oring was out of it’s sealing bore.
2. Yes there is a pressure release and then a pressure apply. The pressure apply flows down the input shaft and out around the stator. That’s the hissing.
3. Yes this works on unfilled new converters. I do this with every converter now.
4. I don’t know how one would go about a vacuum test. The fluid for apply and release is also lube flow for the case and charge flow for the converter. The converter alone would hold 4 quarts of fluid so that is a ton of volume for a vacuum pump.
Just blowing air is my best/cleanest way to simulate the volume of flow if not perfectly the pressure and sealing aspect of a liquid. Hope that answers some of the questions.
So this is a kinda proof of potential concept. Let me know your thoughts
Or perhaps they feel the converter it self is to simple for such a need?
Now the trans side is pretty complicated when dealing with apply and release sides either of which can cause issues to the other even in an on off style set up and even more so with PWM which uses both sides at once to meter slip.
But I like your set up and will watch as it progresses. Converter issues a failure have always been a scourge for trans builders.
I once spent days trying to figure out why on the dyno where i worked some would have lockup other did not and it was frustrating only to ultimately find it was the converter causing the issue. It was a converter we had used for years, But we learned above a certain line pressure it would just dump the lockup oil. Seems though over time and many test runs the apply plate had warped .
Luckily though with lockup most issues are easy fixes, Like the hyper travel valve we add shim to at times, Easy to fix but figuring out what they are first is the hard part.
Then VB wise issue none talk about like everyone mentions the ISO valve side of the converter regulator valve and while yes they do wear and leak and much larger leak almost always exist at the cap side of the valve and If you look at the diagram you can see how this would effect both ends of the valve and function.
I most always install a converter straight down and have the tail down and bell housing up. I've had bearing and seal issues doing it horizontal, and yes being super careful when installing. It just seems so much easier for everything to properly engage doing it my way. Sorta like installing OD splined parts into the multi disk clutch packs, you wouldn't want to do that horizontally.
The big problem with torque converters is your at the mercy of what ever trainee or technician puts it together, and how happy that person is with his employer that day.
