TC/lockup
Old Oct 7, 2024 | 09:49 PM
firewheel56's Avatar
Default TC/lockup
DID i do this right? I have a 74 450SL MBZ with a 5.3 and a 4L60E and 3.8 rear diff (stock) i hooked up the TC lockup to a old school high/low beam switch on the floor to lock/unlock i put power from switch to wire going to ECM for lockup or (intow/out tow) this works for me but i have not hooked up to brake light switch yet i have to add a relay to do this. later i will hook up a superior adj. vacuum switch for engine load. so is every one hooking there tc lockup or is the ECM doing it. at 65/70 flat ground no wind i get 28MPG and at 100MPH the RPM is about 2850 THANKS
Old Oct 8, 2024 | 10:26 AM
bbond105's Avatar
If it were mine, I would use the ECM to control the TCC.
Old Oct 8, 2024 | 11:59 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I too would use the ECM and tune if needed to suit my taste since doing it the way he is talking would require tuning out codes on the PCM anyway
__________________
