trans not shifting
Old Dec 28, 2024 | 04:29 PM
Janders41's Avatar
Default trans not shifting
Hey all I'm having an issue with my 4l60e not shifting out of first gear I was wondering if I have to tune out the abs sensors?
Old Dec 28, 2024 | 11:28 PM
Tranzman's Avatar
Shouldn't have to change any ABS readings.
1st check for codes
2nd The PCM uses the VSS, TPS & MAP/MAF to calculate shift speed and pressure rise. I would check those for proper signals...
You will also want to look at the shift commands and the transmission fluid pressure switch for each quadrants command. I have seen bad FPS command a individual gear and have 1st or 2nd gear only but always sets a code.
Keep in mind that not all scan tools will look at trans data...
File Type: pdf
Old Dec 29, 2024 | 01:22 AM
garadyy's Avatar
You're right, thanks for the info.
