4l60E Separator Plate Holes
Old Feb 18, 2025 | 01:21 PM
Chris.Hanna's Avatar
Default 4l60E Separator Plate Holes
Hello All!
Firstly, thanks to everyone on this forum for the wealth of knowledge provided. I have a 99 Camaro that was a bolt on car plus nitrous last year. I had installed a HD2 kit and Sonnax 4th servo. This winter the car is getting ported heads, cam and an FTI 3200 converter. I decided to tackle some of the common issues with the 4l60e. I’ve added the following parts:
sonnax hd 3rd backing plate kit
7 friction high energy clutches in 3rd set to .025
7-cs spring kit with stock check ball
new bw high energy band
sonnax extra long o ringed servo pin
sonnax HD 2-3 valve
sonnax abuse bore plugs
trans go o ringed end plugs
blocked 4th accumulator
The car has 4.10 gears and needs to shift into 4th on nitrous. If this isn’t possible I understand and will adjust rear gear accordingly.
I'm stumped on what to drill my 3rd feed, BR, and 4th feed too. I’ve seen anywhere from .101 to .156, any suggestions?
Old Feb 18, 2025 | 06:32 PM
bbond105's Avatar
What kind of racing are you doing that will require shifting into 4th gear?
Old Feb 18, 2025 | 08:34 PM
1/4 mile, with a 275/40/17 and 4.10’s it shifts into 4th 110-112 ish mph
Old Feb 19, 2025 | 07:18 AM
2BFAST's Avatar
What happens at the big end if you leave it in manual 3rd?
Old Feb 19, 2025 | 07:36 AM
It hits the 6800 rev limiter. I’m not dead set on using 4th though. I just put the Hd 2-3 valve in so I know I need to leave it in m3. I’ll prob put a taller tire on it or just swap the gears to something taller.
Old Feb 19, 2025 | 09:13 AM
mrvedit's Avatar
Moderator
Let experts chime in, but I wonder if a wide band would be beneficial.(You didn't expressly mention that you had a wide band.)
I don't know if something like a "Super Hold" 4th servo piston is useful or just a gimmick, but I know that people towing with their trucks often want 4th gear upgrades.
Old Feb 19, 2025 | 10:08 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Could have sworn I already did this but for a 4th shift at WOT
WIDE BAND on NEW DRUM, SONNAX DUAL 4TH SERVO, WELL SEALED BAND PIN, .110 SERVO FEED 4TH, BLOCKED 4TH ACCUM and still would suggest my band cooling mod and unless you plan to manual shift to 4th I would consider my overun mod.
But also consider the 3-4 must also hold this , So even though already applied make sure no leaks here and you will want 220- 230 or so max line during the shift.
(Secondary note- For towing and such the three best mods are wide band- sonnax servo- overun mod- band cooling mod.)
__________________
Old Feb 19, 2025 | 10:25 AM
bbond105's Avatar
I think the car would be faster if you raze the shift points for 1st, 2nd, 3rd, 4th a few hundred rpms and then raze your rev limiter to 7200 or 7400 rpms than it would shifting into 4th just before the finish line.
Old Feb 19, 2025 | 10:52 AM
Thanks Frank! I've read all of your tips and tricks. It's just the hole sizes I'm confused on. .110 feed for 4th got it! What do you suggest for 3rd feed and band release? Also, I sadly bought and installed the Sonnax 2-3 valve before reading about your overrun mod. Can I purchase a Sonnax valve to be modified with your spring system? Or send you mind to have it machined? I do plan on adding the band cooling mod as well.
Old Feb 19, 2025 | 10:54 AM
With the stock valve springs I was not interested in revving it that high. Aver the cam and heads going on I think you are right and that would cure needing to use 4th at the strip.
Old Feb 19, 2025 | 01:19 PM
tayto's Avatar
return or sell the sonnax HD 2-3 valve. you can actually achieve the same thing with a separator plate mod. I like Frank and/or maroonmonster 's method but sometimes customer might not want the firmer down shift it can cause. i should probably post how to do DIY method for HD 2-3 valve....
Old Feb 19, 2025 | 01:24 PM
I already drilled the valve body for the Sonnax valve. Not sure how that affects going back to a stock valve.
Old Feb 19, 2025 | 01:40 PM
tayto's Avatar
allowing overruns in all gears with lever in "D", same as sonnax HD 2-3 valve:
block 35a and drill a new hole above 34e. this allows D3 oil (which is available in manual 1, 2 & 3) to feed the overruns. where as before D3 oil would be blocked by 2-3 shift valve when in 2nd (with lever in 3) and D2 oil blocked by manual shift valve when lever in 3rd lever not allowing overruns on in 1st & 2nd with lever in 3rd position.
