700R4 - Torque converter clutch (TCC) lockup harness wire
Is there a harness / wire outside of the 700R4 case for the Torque converter clutch (TCC) lockup?
What does it look like and where on the case is it? I know the TCC solenoid is wired up inside the pan, however where does this wiring connect to outside the case?
What are you using to actuate the TCC lockup solenoid?
GM used a switch on the brake pedal and a vacuum switch along with a pressure switch in the transmission. TCI sells a vacuum switch kit that includes the harness and vacuum switch.
An 86-model car should have the plug for the trans from the factory. What transmission came in the car and was the car commuter controlled?
