V8 trans behind 3.8 Camaro
Old Apr 3, 2025 | 07:47 PM
camarojunkie85's Avatar
Default V8 trans behind 3.8 Camaro
Hello all. Question about switching a trans. I'm in the midst of a turbo 2001 Camaro 3.8 build. I know the 4L60 behind them is the 245mm shaft. I do have the bolt on bell housing. I've been rereading a few threads about overall lengths and stuff.
But my confusion is would using a 298/300mm trans either from the 4.3 or LS trans fit with the 3.8 bellhousing on it. I know the housings are different sizes between the 60/90° engines. But will the larger bellhousing convertors fit in the 60° housing? I've read a few guys switching input drums and what not to beef up the 245mm. But I feel like just starting with a larger period would give more options. Much appreciated.
Old Apr 4, 2025 | 08:59 PM
Tranzman's Avatar
I don't believe that you can get a 298mm converter to fit in a 60 degree V-6 transmission. There may be a high stall converter that will need a 298mm input shaft though. you will need to check with a converter company for that. It seems like I saw something in the Sonnax converter section of their website that showed a kit for using a 245mm converter body for the high stalls.
Old Apr 5, 2025 | 12:36 PM
Sorry if I confused, looking to just use a 298/300 complete trans, looking to see if my 3.8 bellhousing will fit that trans period and work behind the 3.8. Eliminating the 245mm trans all together.
Old Apr 5, 2025 | 05:31 PM
Tranzman's Avatar
Yes you can use the 60 degree bell-housing with a gen 2 transmission but your input shaft will be different so your 245 converter won't fit in to it. That is why I said something about Sonnax and their custom converter kits. They may have something so a 298mm 30 spline input shaft can be used in a 245mm converter core.
Why do you think a 245mm input shaft won't work? I have wondered if a S10 2800 stall would work in an application like that.
The difference in the GEN 2 298mm and the GEN 3 300mm converters is the GEN 3 uses a 5/8" deeper bell-housing to accommodate the larger/thicker converter. So I would not even attempt a 300mm shaft set up.
Old Apr 5, 2025 | 10:17 PM
I was just looking to just start with beefier trans period. I have a few. Just tossing the trans from the 3.8 and beefing up a V8 trans for the 3.8. That's all I was looking to do. Not switch any parts for the time being. Just doing a junkyard build. I just assumed that with lower HP engines, the small trans was a weakll link and probably wasn't built to handle much above factory HP.
Old Apr 6, 2025 | 12:22 AM
Tranzman's Avatar
I'm not sure about the 3.8L transmission comes from the factory but all 4L60E's can be beefed up. The only one that I'm sure is a different set up is the 2.2L S10. The entire gear-trains are all identical. The exceptions are the the obvious input shafts/bell-housing externally. The 2.2L 3-4 clutch has 5 frictions instead of 6 and has 7 steel instead of 6. The servo is smaller for the band too. Any decent builder could easily take any combo the 3.8L might have and turn it into a V-8 version...
