4L60E Internals
Old Apr 18, 2025 | 08:08 PM
rjpower's Avatar
Default 4L60E Internals
Can someone tell me if the internal hard parts from a 07 4L60E such as pump, shafts, drums ,planet set etc. can be used in a 91 4L60/aux valve body trans
Old Apr 19, 2025 | 01:58 PM
dixiebandit69's Avatar
Theoretically, yes, the geartrain is "interchangeable," but what are you going to put it in/ what engine is it going behind? What converter are you planning to use?
@FranksCustomTrans has a pretty cool modification to use the later style pump with the TH700 valvebody, but I can't find the link right now. I'm planning to do that on my '90 Squarebody Suburban soon.
Old Apr 19, 2025 | 03:03 PM
rjpower's Avatar
I'm a trans builder but haven't tried using the LS trans stuff In a 4l60 yet. it's for a BBC street rod thing.
It will be a driver not a racer. Lots of torque but no traction. As usual. It's a NO Dam Computer deal.
Old Apr 19, 2025 | 03:33 PM
Scott Danforth's Avatar
Originally Posted by rjpower
I'm a trans builder but ....
then you know the answer
Old Apr 19, 2025 | 05:17 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
The planets sure will work in fact all the assembly will work except for output shaft, input drum-(can be used with shaft change) and pump -(as mentioned I do have instruction on how to use a 4l60e pump in a 700r4 but the specific 07 pump you have cannot be used. An earlier 298mm 94 up can be retroed easily)
Hope this answers questions.
__________________
Old Apr 19, 2025 | 05:56 PM
rjpower's Avatar
thank you, sir. You're a gentleman , Where is the info on pump change. The info I have on that is very old.,,, RJ
Old Apr 19, 2025 | 09:33 PM
LS1Tech Sponsor
https://ls1tech.com/forums/automatic...l#post20547808
__________________
