4L60E Delayed Shifting If Launched
Possible causes would be of course badly worn clutches/frictions.
But more likely AFL issues. . If it was worse on the 2-3 I would say too much AFL and flooding solenoids . But because its worse on the 1-2 I would suspect LOW AFL from a badly leaking AFL valve and low AFL feed to the solenoids .
Your 2-3 shift time is typical for a stock 2-3 valve timing sounds close to what I would suspect little over but 3-4 set may be a little tired.
The 1-2 takes considerable more force to apply the 1-2 valve, So I would say Worn AFL . But other possible causes are Leaky oings on the 1-2 solenoid or leaky orings or damaged screen in pump.
Things you could try short of a removal rebuild are- Replace the AFL valve with a GENTLY OVERSIZED ONE from global https://globaltransmissionparts.com/...CZBBr_WUExhrZo.
Replace orings on shift solenoids or solenoids themselves
Also, what many people miss, is that the trans won't shift until BOTH (!!!) the WOT RPM and WOT MPH table values are met. For this reason, I generally set my WOT MPH about 20% below what I need so that any changes to the WOT RPM will change the shift point. (Note: some tuners set the WOT MPH to zero to avoid this problem; I don't know if it has any strange results; I just set mine 20% below what is needed.)
