4L60 Operating Pressures
Old Sep 23, 2025 | 01:37 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Sure Frank, that's fine.
I pretty much see all that the same...
Except that the OP's Line Pressure only being 200 Psi in 3rd, 4th, Etc, is most likely due to some decent leakage.
His Line Pressure numbers were all decent otherwise.
Yes and I would bet as I have done extensive testing here , his primary leak is the BAND PIN TO BORE. EVERYONE I test of late is MASSIVE applying aair to the 4th servo or sealed through the 3rd acum it just pours out through the weep hole in pan or back though the 4th servo feed depending on which i am testing , PATH OF LEAST RESISTANCE .
__________________
