4L60E automatic transmission slipping 2nd and 4th
Press on the servo cap with a crowbar and hold a ruler nearby to estimate how much it moves in.
1/16" to 1/8" is a good amount. 3/16" is marginal and anything over 1/4" is going to cause the band to start slipping.
You might be able to get a bit more life out of it by buying a longer servo pin or welding a blob at the end of the existing one.
Removing the entire servo does not require removing the trans, although on a Firebird the frame will get in the way; you may have to remove the drive shaft and rear trans mount to tilt the trans down enough to remove the servo.
