Do yourself a favor,bump your idle to 700rpm
Actually I used to adjust my idle by using the adjustment screw and I got some hunting of the idle, but since James did it through the predator it is perfect no hunting or anything.I also made sure that my ohm reading was at the original reading of .85 (before I put James tune in).This is the reading I took before I did the throtle bump stop mod.(I took a reading at rest position then when I finished the bump stop grind).
