Transmission questions. Please advise.
possibly up the 2-3 pressure some, and then
play with the shift MPH to give you the "lead"
you need to clear the limiter.
I've noticed something very kooky about the
Force Motor table - the 100% column is full of
1245 (a large blow-off that would knock line way
down). In the trans shift settings of HPTuners there
is also a max line field that is set to like 95% so
(theoretically) you would never see the hokey
line drop. But, if this max line got raised you might
be interpolating over to a kooky line drop. You might
want to get into that table and set the 100% value
the same as the 90%, 95% values just for luck and
see. Check it out, anyway - dunno whether the '98
is all the same as my '02, there might be other odd
things of a similar nature that need a comb run
through them.
