Benefits from aftermarket flexplate?
The earlier flexplate is sturdier. On a '98 I'd call it a
"don't bother" unless you are spinning higher and
putting out well more torque than stock?
I've done many more mods since then and I have not had any other problems.
It doesn't seem like it's been to much of a problem with the other members or at least they have not posted that much on the subject.
I wouldn't replace it unless you are having problems.
Regards,
Al
One less thing to worry about. Only a couple hundred bucks, and it's SFI rated. Safety is always a good idea.
I replaced mine with the TCI SF-29 flexplate. The transmission shop told me the TCI unit was very heavy duty and well made, and my entire car could blow up and the flexplate would still be intact.
SteveC
