How fast can you spin the 4L80e ??
I've kinda finalized my cam decision (GM HOT cam) and want to make sure that the tranny will be able to live to the 6500 rpm's that I want to spin the motor....
TIA
limit. Like on the 4L65 they rated the RPM lower
because of the 5-planet cluster not having the
oil passages needed to cool it as well as the
'60. A few seconds at a time will probably not
kill you but it might not be happy on sustained
high RPM runs.
Would be interesting to know what GM had in
mind as the RPM limiting components.
A word of caution though, the drums in these are all steel, not aluminum. That is great for strength but it's also a lot of weight to be spinning in there and if they come apart it will tear up the car and the occupants.
