TC install help... too far from flywheel?
So, am I still on track here or is something screwed up?
Also, what is the total capacity of the 4L60e? And is it true that I should fill it with like 4 quarts, and then crank and moee through all gears, and add as I need it?
Thanks a lot,
Derek
Don't rely on the converter bolts to pull the converter closer. There is a small hole in the bellhousing, use a screwdriver and pry the converter foward to push it against the flywheel, then install the bolts.
Total capacity should be around 11-12 quarts. Put in about 7 or 8, then start it up. Add fluid and re-check accordingly.
Could it be a truck thing?
As far as contacting the builder... he was the first one to reply to this post. (Thanks man, nice service!).
And guys... its not that far, I'm talking maybe an 1/4th.... well more like 1/8th of an inch. I just know that tolerances are tight and I want to be on the money.
Bernard--- I can't wait till sunday when I get some time to finish the install. Hopefully my new tune will be in by then, and I can drive it around. What kinda break-in time should I give it before I really give it some gas and see how it performs?
PS: Bernard..... Southeastern just plain mangled my cooler. I'm not going to make a deal of it because 1) its free and 2) I've got a B&M cooler somewhere in the storage house that I bought for my old truck a while back. I just have to tear threw that storage room and find it.
-Derek
Sorry about the cooler. Southeastern has had a stellar reputation, I use them for everything I ship out. If you can't find your other cooler, please let me know and I'll get another one headed your way.
