4l60e
Old Oct 23, 2004 | 02:16 PM
kaibeto's Avatar
Default 4l60e
My Tranny Went Out And Had Rebuilted,bolted Back To The Engine And Fired Up The Engine.everything Looks And Sounded Good So Far,then Pressed On The Brake To Shift In Gear But,it Wouldn't Allow Me To Shift.could The Problem Inside The Trannsmission Or Outside.also Is There Any Type Of Tester Available Thats Would Help.the Engine Is 350 And The Transmission Is 4l60e.
Old Oct 23, 2004 | 04:50 PM
TeamTripp's Avatar
With the engine off, crawl under the vehicle and pop the shift cable off the shift linkage and try to manually move it through the ranges. If it will move, the problem is in the vehicle. If it doesn't move, its in the transmission.
Old Oct 23, 2004 | 06:21 PM
kaibeto's Avatar
reply to team tripp,follow thru on moving selecter manually.which it does with no problem.check the fuses.shift cable and what else would likely cause this problem.
Old Oct 24, 2004 | 08:57 AM
hefdaddy007's Avatar
did you push in the brake?? just a thought or check the brake switch if it has one for the tranny shift
Old Oct 25, 2004 | 10:25 PM
kaibeto's Avatar
check out everything ok, but the electrically,its not sending signaling that the brake is depressed.
