Quick Th400 swapp question..
Old Dec 6, 2004 | 11:56 PM
Slow Z28's Avatar
Default Quick Th400 swapp question..
When going from M6 to the TH400, you can swap over to a automatic pedal set. Now the question, does it have to be from an LS1 car, or could it be from a '97 Z28 if it's going in a '99 Z? Do you HAVE to swap the pedals over, or is it more for "cleanliness"?
Chris
Old Dec 7, 2004 | 06:03 AM
DERTY's Avatar
The Bull
You don't have to swap the pedals over. You can just unbolt the clutch pedal and make the three pedal setup a two pedal setup. Works fine.
Old Dec 7, 2004 | 09:58 AM
Slow Z28's Avatar
Thanks Derty
Old Dec 7, 2004 | 10:20 AM
kp's Avatar
kp
either that or just leave the clutch pedal and the the over center spring will hold it down on the floor if you are really lazy like myself
