TH400 pan gasket
Anyone have a part # for a better gasket? Are there metal gaskets that can handle more torq?
EDIT: Read on for more discription, sorry for being so short the first time.
So I pull over and it smells like burning oil. I grab a rag, wipe the headder, and notice the fluid is red. So I look under no drips... Check fluid all is good so I continue on to the next exit about .5 miles.
Get under the car and the only sign of anything is tranny fluid on the exhaust and looks like it might have came from the gasket. There was a couple small drips on the bolts and the gasket was saturated. That's all I know to do as of now is change the gasket. It dont leak sitting there at all. Only under WOT I'm assuming. I limped it home and all was fine.
#1 that's the only sign of moisture on the tranny (atleast from a quick look at night with a flash light)
#2 Two weeks ago the gasket looked a little wet in that area. So I retightend it down. Now I have a bigger leak. And after searching I read NOT to go to tight on the rubber gaskets. And it looks to be bulging out in that area.
Where else would spew fluid under a load?
It won't blow out of the gasket.
Sorry I dont know much about Auto's, This is my first and the tranny was in the car when I got it or I would know more about it.
I replaced the gasket with a ruber one and what do you know I guess I over tightened it. It's leaking now just sitting there. AHHRGG LOL I did not go very tight at all either.
I tried to do all the recomendations. Cleaned it up well, put it on DRY, tightened by hand then went back with a 3/8 wratchet and tightend them down. Not anywhere near TIGHT. I could have went a lot further. I'd say les than a turn past fingertight with a socket in hand.
The only thing is one area of the gasket(front) was saturated before I got them tight. I would wipe it off and fluid would drip onto it before I could get the pan up and tight. I dont see how I could prevent that.
I guess ill look into a GOOD gasket if I can find one and try this all over again.
If you have a cast aluminum pan, never mind
