shift kit problem
Old Jan 10, 2005 | 06:54 PM
ramjet02's Avatar
Default shift kit problem
I have a 700r4 that i installed a shift kit in. i get everything back together and go for a drive and it only has first and third gear. I'm not sure if a check ball is in the wrong place or what it could be? Any help would be greatly appreciated.
Old Jan 10, 2005 | 08:11 PM
jxaxsxoxn's Avatar
What year 700R4?
What brand shift kit?
Old Jan 11, 2005 | 09:27 AM
Big Rick's Avatar
91 tranny with b/m kit
Old Jan 13, 2005 | 06:57 PM
gen 3 bu's Avatar
do you have reverse?
if not the tranny needs to come out and the reverse reaction sun shell replaced.
http://www.transmissioncenter.net/4L60E.htm
#17. 4L60E heavy duty reaction shell (1998 up new style). Cost $39.00
Qty 12345
√ #17X. 4L60E Extreme Duty "The Beast" reaction shell. Redesigned sun gear shell for the 700R4 / 4L60E transmissions by strengthening and reinforcing the neck collar spline area using thicker material. Known for loosing reverse, 2nd and 4th gears the 700R4 sun gear shell has a very high fatigue failure rate. This is the shell you want to install in a 700R4 or 4L60E that's behind a 300 plus horse power motor. This part holds in 2nd, 4th and reverse. (Not one broken in 2 years.) Cost $56.00
Qty 12345
Old Jan 14, 2005 | 10:52 AM
itchygomey98's Avatar
If it's a check ball problem, I think you would have to have 2 of them in wrong. Did you get the one that goes on before the seperator plate?
Old Jan 16, 2005 | 07:02 PM
SSkeet's Avatar
my 4l60 lost 2 and 4 once and turns out the kevlar band i had in had snapped in half...
