Help...I was told this is a PCM/Tuning problem.
When I let it hook back up it will stay hooked up as fast as I want to go, it only does this weird un-hooking thing after I'm cruising steady for a little while.
Other than this, the tranny/converter seems to work perfectly during all other types and speeds of driving.
One more thing I notice in every gear: If I mash the gas all the way to the floor, it will over-rev for a second at the top of each gear before it shifts.
Thanks.
When my 2nd trans went, if I mashed the gas it'd rev up like it was in neutral (from a stop or roll) but if I eased into it, it'd be ok most of the time... generally i'd have to feather the gas to get it to shift gears...
Did this start happening immediately after you got a new tune? If not, then it's definetly not the tune and most likely the transmission
I don't know transmissions well enough to know exactly what's going on though... so not sure what actual parts may be busted if it is the trans...
Fluid is full and very clean. No burnt smell at all.
I guess its the tune than.
I can also take my foot off-and-on the gas and nothing happens, its just like it popped into nuetral. I have to manually shift it to "3" to make it hook up again.
sounds like under high torque either the converter is slipping like crazy or the transmission isn't able to hold the gear
Maybe I'll get lucky and Futral can figure out whats wrong when he does all my engine upgrades and gives it yet another new tune.
Thanks anyway for the help.
You always post about racing from a roll, 50 - 150 mph. Maybe its time for a M6 swap and sintered iron clutch.
