Horribile Downshift during a WOT pass
Carlos Villalon, Jr.
Might be a harness intermittent, since the gear select
I believe is all electric. If one of the control signals drops
you could shift gears uncommanded (which is why I ask
about what the logger says, about that).
As far as settings, I think with the looser converter you
might want to increase the gap between your upshift and
downshift MPH in the part throttle tables, the higher-TPS
cells. I left only a 2MPH "gap" on the 2-3 because I like a
responsive kickdown, but since you are way looser than my
setup this may allow you to "flutter" where I would never
see it.
