Cracked Flywheel
Has anyone else had a similar problem with this engine/tranny combo? The cracks are concentrated from the crank bolt holes outward and toward one another. The only thing that the mechanic can see is a bit of additional movement in the crank in and out.
Hope someone can shed some light.
There was nothing obvious about the torque converter when it was out. Everything seemed fine. Can't really tell with out measuring though.
What would make the crank drift with such force that it would crush the flywheel? Even with some fore and aft play, all the force within the engine is directed at turning the crank not forcing it back and forth.
The other thing that we looked for was some sort of casting imperfection that was preventing the engine and tranny housing from mating square to each other but, again nothing obvious.
Look for the code in the Glovebox.
M30=4L60-E
M32=4L65-E
MT1=4L80-E
Sorry to disappoint you.
