Shift Kit: Good or Bad Idea?
Old Feb 21, 2005 | 06:00 PM
jxaxsxoxn's Avatar
jxaxsxoxn you misquoted what I said to humiliate me and to make me look foolish ... don't ever do that again. That was your point in your opening statement about me, was it not?
First off my opening statement was not towards you it was just meant to point out how funny that sounds. What does it have to do with YOU....NOTHING so how can you take offense to it? Thats what I thought. Guess I was wrong.
So **** it, I'm sick of offering advice for free or opinions or nothing, whatever you choose to call what I do here.
Can't joke with someone without putting a million cute little smileys after it I guess. And still it's not taken as a joke. I'm done with this, you all can do without me. I've got better **** to do. .
Old Feb 21, 2005 | 06:04 PM
jxaxsxoxn's Avatar
But I don't really favor
stacking up six washers just to shock the hell out of the
drivetrain
I've been thinking more along the lines of the simple B&M
shift improver kits, though I haven't seen much on these
Sounds good in typing.....
Transgo gives you washers to select from, three.
B&M gives you little pieces of steel tube to do what the washers do. Block the 1-2 accumulator.
B&M is ****, so you'll never hear otherwise from me.
Old Feb 21, 2005 | 07:14 PM
JEB99TA's Avatar
Robbie, nice shootin' the bull with you on that ride today. You'll love the converter when you get it done. I think you did good with the TCI ... takes a little getting used to.
Rolling hard into the gears without breaking the steady, forward momentum of that 3,680 pound rocket is what you want. Jerking through the gears and disrupting the momentum is not how you want to race ... will cost you that 1/10th which will lose races for you ... just my .02 cents.
I'll let you know on the tires. I have to call and order the Nitto's tomorrow ... should have them on by the weekend and the 255's out front are yours if you still want them.
Old Feb 21, 2005 | 08:27 PM
RevGTO's Avatar
Pontiacerator
Originally Posted by jxaxsxoxn
You can do all you want to the programming and you're not going to get the same fluid volume to where it needs to be, you can raise the pressures and it'll stuff as much it can through a small feed holes. But thats not going to be the most beneficial.
This is the deal. People often think that a shift kit is a harder, faster, shift and are interested only if it's going to make their car quicker. The Transgo kit is about better fluid circulation to the clutch packs and planetaries, a more positive TCC engagement, as well as better shifts. And no one has to use any washers in the accumulator - use what YOU want to get the result YOU desire.
Old Feb 21, 2005 | 08:33 PM
FLTransAm02's Avatar
No **** I get it......but why do they do this.
Do they have 15 people with 4 1/2 years? 10 with 7 years? or 2 with 35 years?
It's a bogus sales pitch that means nothing to me.
Do what you want.
Originally Posted by JEB99TA
All 4 of these guys have over 70 years experience as transmission specialists
jx, way to read..
Old Feb 21, 2005 | 10:11 PM
James B.'s Avatar
4L60-E's are not strong enough to survive being set up to shift hard. The splines, planet carriers, reaction shell, drum, etc. are ALL to underbuilt to handle the shear jolting forces.
A shift kit set up to shift hard will kill the transmission in short order. In fact, there is a thrust washer against the rear plent that can become overworked with hard shifts or electronically (bad programming) increased line pressure enough to shread it and lodge it into the gears. This will be expensive death too - damaged hard parts.
Set it up to shift firmly but smoothly without any banging or jolting and it actually will last longer. The Transgo fixes problematic things with the valvebody too, it's not just a simple "shift-kit."
Old Feb 21, 2005 | 10:46 PM
jimmyblue's Avatar
Moderator
So, does installing the Trans-Go with no changes to the
pressure make for better operation or reliability? What
about if you don't take out the plunger and grind on it?
Old Feb 21, 2005 | 10:53 PM
blind527's Avatar
Will a tranny cooler give me more sufficient shifts? I just got my PCM reprogrammed to a lot harder shifting, is a tranny cooler necessary? I'm also getting a torque converter. I ask about the tranny cooler because I see a lot of people ahve them, is it wise to get one when you get a shift kit/PCM tune?
Old Feb 22, 2005 | 12:09 AM
buffman's Avatar
I'm going to agree w/ james. That's prolly why the trans in my car only lasted me 11k (well besides the fact the guy has poor workmanship) . The jackass local rebuilder (I was broke at the time), turned up what he called the force motor (don't know the technical name of it) to increase line pressure and firm up shifts instead of actual shift kit.
Later after blowing the trans up I find out increasing line pressure that way is a very bad thing, but unlike what he told me that increased my line pressure all accross the board even while shifting from park. I never knew how hard the trans was or wasn't supposed to shift, but my 4300lb car (b-body) would bark the **** out of the tires at less than 1/4 throttle on the 1-2 shift going 20mph.
When the new rebuilder tore the trans apart besides the poor work he found the reverse drum had been sorched, The foward sprag had completely reversed itself, and the input planet literally exploded.
My new trans has a trans-go shift kit and I love it. I only have around 500 miles on the new trans and converter, but the shifts are nice and smooth at part throttle and affirmative at WOT. the trans came installed w/ no washers for the shift kit, but I will be pulling the pan and adding one washer, just to make it a tad firmer. I say for the money they're well worth it. They help address the few problems that arise in the trans such as the slow delay into reverse.
Matt
Old Feb 22, 2005 | 04:01 AM
Automatics's Avatar
Restricted User
You want the shifts to be smooth at light throttle openings, & with the shifts getting firmer with more throttle, this will give you the best chance at a long life with the minimum of problems. Now you see what I have been saying for years, you do not need firm shifts at light throttle openings, as they can be destructive, along with all the other good side effects.
Old Feb 22, 2005 | 05:59 AM
2MuchRiceMakesMeSick's Avatar
Youll have to get one when you get a converter.
Old Feb 22, 2005 | 12:19 PM
  #32
JEB99TA's Avatar
I was asking the same thing ... wish I had went with a 24,000 GVW, but, my 19,000 one is sufficient with the 160* thermostat, I think. Not sure how a shift kit would effect the tranny temps (FLTransAm02), but, it would be worth looking into. Anyone know for sure?
Old Feb 22, 2005 | 05:36 PM
  #33
JEB99TA's Avatar
Anybody?
Old Feb 22, 2005 | 06:45 PM
  #34
buffman's Avatar
Personally I don't think a shift kit would effect trans temps.
Matt
Old Feb 24, 2005 | 05:41 AM
  #35
JEB99TA's Avatar
Robbie, the more I see here, the more a shift kit sounds good. Just not convinced that drilling the tranny is a good idea and the big thing that has me concerned is that there are several shops I called over the past few days that simply will not install the shift kit you're inquiring about. Ask Mike Norris or Jake Lamotta. I haven't called them and they are very respected PERFORMANCE shops in our local area. I'd say just go with their rceommendation if you have the financial option of having the kit done while at the same time you're doing the TC install.
My point is that I don't think one is needed for your level of converter with your 3.23 gears. for the goals you are seeking. I also don't want you to regret not doing it later. I'll take you over to both places and talk to them if you want, on Saturday. Stop by if you want to discuss.
Old Feb 24, 2005 | 07:24 AM
  #36
Yea, I talked to Norris, he said a shift kit couldnt hurt, but that it wasnt really too neccisary.....Im not sure yet, im still saving up..
Its frustrating having a 3500 stall converter under your bed, and not having the funds to have it installed yet :-/..
Soon though...!Any news on those tires Jack?
Old Feb 24, 2005 | 07:42 AM
  #37
DRACO911's Avatar
Just be willing to buy a new transmission if your breaks. I put a shift kit in mine and the pressure built up so much that the piston housing blew out and cracked the case. No Case No Tranny. You have to buy another one, and you can't even use yours as a core trade.
Thank god mine was still under warranty and the tranny guy at the dealership was cool. He aslo told me that if I want hard clean shifts just raise the line pressure. That keeps it under the safe limit, as soon as you start changing things inside you risk damaging the Tranny. That is what I was told. This is from a guy that used to work on race cars.
Old Feb 24, 2005 | 08:21 AM
  #38
Wouldn't raising the line pressure enhance the risk of hurting something? more pressure = more stress?
Old Feb 24, 2005 | 08:33 AM
  #39
DRACO911's Avatar
What do you think you are doing when you put in a shift kit. Except then you are taking it out of normal toleranceso fthe Tranny.
Old Feb 24, 2005 | 09:56 AM
  #40
RC_Y2KWS6TA's Avatar
My experience with a custom shift kit. I like it!
About 2,500 miles ago I had a PI vig 2800 converter installed at a respected transmission shop. I also had the owner put in a enhanced valved body and pump. Bascially, he machined me a custom shift kit to enhance the shifting, increase transmission fluid circulation in certain gears were in the stock form it typically doesn't have enough, blah blah.
I can't tell you if it will increase the life of the transmission because I haven't driven it 10s of thousands of miles.
Driving the car, it shifts immediate and without harshness. Normal driving, I can barely feel the transmission shift from 1st to 2nd and 2nd to 3rd. With the converter, the enigine revs between 2k and 3k and the 1 to 2 shift it shifts without the rpms dropping.
I think its a pretty sweet set-up and compliments the stall converter. Also shifting in park and reverse is exactly like stock.
