A4 bogs after 1-2 and 2-3 shift after vig2800 and TransGo shift kit installation.
Re: A4 bogs after 1-2 and 2-3 shift after vig2800 and TransGo shift kit installation.
[quote]Originally posted by JNorris:
<strong>What criteria does the PCM use to know when and how much torque management to use?</strong><hr></blockquote>
I have NO idea. <img src="images/icons/confused.gif" border="0">
When I throttle is very lightly, shifts are pretty smooth. When I drop the hammer, it shifts pretty well. Anything in between and it's like I hit the brakes between the shifts. <img src="images/icons/confused.gif" border="0">
<img src="images/icons/smile.gif" border="0">
Moderator
So far the only time I have any problems is at WOT. Not every WOT shift but about 90% of them. <img src="images/icons/confused.gif" border="0">
LS1Tech Premium Sponsor
I just had my TM deleted with Ed Wright's tuning, and the difference is night and day. The shifts are quick, and the car actually keeps charging instead of having the dreaded hesitation that I was used to. Between the higher shift points, TM deletion, and 3.73's, my car ought to have no problem making it into the 11's next time out. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
You are almost identical to me. I have a Vig3200, Transgo and Cooler. All my shifts, 1-2, 2-3 and 3-4 drop off significantly. I guess it was like that before the install but I'm thinking I didn't notice it without the shift kit. A reprogram is all I can think of. <img src="images/icons/frown.gif" border="0">
Moderator
Thanks. I will give Ed a call.
Will you be able to program out TM problems with LS1 edit?
John
John
<strong>Will you be able to program out TM problems with LS1 edit?</strong><hr></blockquote>
That's a great question. I'd like to know that too. <img src="images/icons/smile.gif" border="0">
FYI : MTI is going to do my program and I'll still be able to retain the use of a HPP3. <img src="images/icons/smile.gif" border="0">
