help ASAP ..!!!
Old Feb 25, 2005 | 01:33 PM
artic-z28's Avatar
Default help ASAP ..!!!
my buddy stripped a converter bolt, but it the Allen head one.. MY question is how do i Get it off... i tried a hammer and chisel ..and bigger aleen heads still no luck, i was going to try them craftsman take any bolt out deal, the the bolt it round???? any ideas???
Old Feb 25, 2005 | 03:18 PM
jay_99z's Avatar
Grind the head off and drill it out.
Weld a socket onto it and then back it out?
Old Feb 25, 2005 | 05:22 PM
GregWS6&z28's Avatar
here's my converter bolt that was stripped out
that is the only thing we could weld to it. welding sockets to it didnt work, or welding allen headed sockets. The long bolt also helps because it gives you clearance past a nub on the block that gets in the way. Youll see it under there
Old Feb 25, 2005 | 06:22 PM
Frostbite's Avatar
Thanks for the guy that replied. A friend of mine took an air chisel (sp) and chewed it all up and pulled it out with a hammered on "Bolt-Out" socket.
It was tore up pretty bad. I leave tomorrow morning to Pick up my Evil Tranny, tranny cooler, and stall from Speed Inc in Chicago.
