pro rachet good idea for 4l60e
Also, our Pro Ratchet cannot be used with a GM 4 speed automatic transmission, it is designed for 2 & 3 speed automatics.
No reason you can't use a Pro Rachet w/a GM 4 speed auto. B&M part # 80842 Universal 3 & 4 speed model.
It needs set up like this:
upshift table
1-2 255mph
2-3 255mph
3-4 0mph
downshift tables
2-1 0 mph
3-2 0 mph
4-3 255 mph
And yes I love my prorachet shifter
http://www.hotrodhawk.com/fire_breathing_firehawk.htm
In first your in first, in second your in second, in third or fourth you have normal automatic shifts.
You either start in 1st gear when selected, or second gear when selected, otherwise in 3rd and 4th it will go through all the gears up to the selected one.
You either start in 1st gear when selected, or second gear when selected, otherwise in 3rd and 4th it will go through all the gears up to the selected one.2000 too
