TH350 Torque Converter Question?
Old Nov 20, 2001 | 01:44 PM
GeorgeC's Avatar
Default Re: TH350 Torque Converter Question?
I don't know about all of the components in Yank's conversion kit, but...
The stock flexplate already has 2 bolt patterns on it. One for the stock 4l60E converter, and one that just happens to line up perfectly with a TH350 converter. The hub depth is different, but it seems to be close enough on my car to not matter. The hub does go into the back of the crank, but barely. Turbo Action sells a hub adapter/spacer for about $20 that goes on the front of the converter. I still have mine, but don't use it.
BTW, if you haven't guessed by now, I have a TH350 and a JW converter in my car... In fact, I believe I had the first TH350 trannied LS1 street car around back when I did my conversion two years ago.
Old Nov 20, 2001 | 08:51 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Thanks George! So that means I can have my choice of any TH350/400 torque converter I want if I go that route. It looked like everyone was buying the conversion kit, I thought it was because of some kind of "special" one-off converter housing or something. <img src="images/icons/smile.gif" border="0">
Old Nov 21, 2001 | 12:35 AM
-Joseph-'s Avatar
Default TH350 Torque Converter Question?
I have been building TH350's for a while now, I know Yank sells a conversion kit to go to a TH350. My question is, What is changed on the TH350 Torque converter to work on a LS1 Flexplate? I'm assuming it has something to do with the converter bolts and possibly the depth of the center hub? What would stop me from using a $300 3500 Hughes stall converter is the main question? TIA
Old Nov 21, 2001 | 02:47 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
[quote]Originally posted by 1BADTA:
<strong>The one nice thing with the Yank kit is the bellhousing adapter plate to make the TH350 bellhousing use all the bolts to mount up.
I had issues with my tranny & converter straight out of the crate, a $410 rebuild on the new $4800 tranny later and a new converter and my car is running properly.
We'll see how this is taken care of.......
~ Spencer</strong><hr></blockquote>
OUCH! You're NOT alone. My Yank TH350 was the biggest POS. The shifts weren't worth crap, and they were inaccurate as hell. I also had a hole in the front of my trans that was dumping fluid ALL over the place! <img src="images/icons/shocked.gif" border="0"> It took us over a week just to get the trans to work so I could drive the car. I have a friend that lives in the DFW area, too, and he went through total hell with his TH350 conversion on his '98 Z28 M6 car. He had to fight with Yank for quite a while before getting some money back. He had to have a rebuild on the trans in less than 500 miles, and the guy at the trans shop told him that he's seen stock TH350's with better parts in them!
Yank converters seem to be working well now, but the trannies are a WHOLE different story. I think they should leave the trans building up to the guys that know what they're doing.
__________________
Old Nov 22, 2001 | 12:40 AM
1BADTA's Avatar
~ Spencer
