what B&M trans cooler to get?
Old Mar 6, 2005 | 12:41 AM
whataretheodds's Avatar
Default what B&M trans cooler to get?
i see that on some vendors website they offer 2 B&M trans coolers on is part #70264 that is up to 24,000 lbs and the other one is #70268 up to 19,000 lbs, which one would i get? or it does it matter?
Old Mar 6, 2005 | 12:56 AM
Jake the SSnake's Avatar
get the biggest one you can fit. I have the ftra and I had to mount mine between the radiator and ac condenser.if you mount it in front of the radiator or in between there is plenty of room either way.
Old Mar 6, 2005 | 07:19 AM
87gnx's Avatar
Yep, the more surface aea the oil tralels through( in the cooler), the more cooling effect you get. I have the 24,000 and it works fine.$.02
Old Mar 7, 2005 | 06:14 AM
Gregg_98TA's Avatar
I have the 28,000 B&M unit due to the AN fittings. I plan on putting Aerquip hoses on in the spring.
Old Mar 7, 2005 | 09:03 AM
C5 Purple Haze's Avatar
I also have the 28000 B&M cooler, it doesn't come with fittings or hoses. However you can buy what you need to install it at Auto Zone
