Advise: Need input on how everyone had there transgo kit set up?
Hey all:
I will be taking my car in on Tuesday to my friends trans shop and having them install my tci 3,200 stall, trans cooler and also a transgo kit.
My question is when you had your's installed how did you have it set up? I am looking for it to last and not break my neck between shifts. Just want some input. Thanks
Theres more to it than washers.
It varies per vehicle. Depends on how the trans is built. What type friction material the clutches are and what their clearances are set at. Plus the seperator plate hole sizes, servo size, boost valve size, etc.
An experienced trans mechanic can set it up to shift the way you want it to.
You can't just set it up the way some guy on the internet has his set up.
Call me when you have the transmission in the shop & the guy is getting ready to install the Trans-Go kit, I will walk him through the setup on the shift kit modifications. 800 7763288
